Old 08-12-2018, 03:38 PM
shanman94 shanman94 is offline
Default Can't get it off...pto clutch
Hi All,
I'm trying to remove the pto clutch from my 1440 because I need to replace the rear (front of mower) crankshaft oil seal. Turning the bolt just turns the engine over. I've sprayed some WD on it and will let it sit to see if it loosens up anything. I'm a mediocre mechanic at best but try to fix what I can. Any ideas? This site has helped me many times before, it's GREAT!
Old 08-12-2018, 03:54 PM
swacor swacor is offline
I've always used an impact and never had a problem!!
Old 08-12-2018, 03:56 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
air impact
I know not much good advice if you don't have one
I have a 24v impact that'll take them off too, sometimes
my brother has a corded impact from HFT that will do it too, sometimes
JD x475
Old 08-12-2018, 04:08 PM
cooperino's Avatar
If you dont own an impact gun. You need to "shock" it loose. That's what an impact gun does. Use a socket that is as shallow as possible. Hold your ratchet near the head with one hand and bump the end of the ratchet with the other using the inside of you palm or even a dead blow mallet.
Old 08-12-2018, 04:52 PM
I was thinking impact was the key, I may have a buddy that has one. I may try the end bump technique until I can get ahold of my friend. Thanks Y'all!
Old 08-12-2018, 05:42 PM
Do you own a pipe wrench?
Old 08-12-2018, 06:23 PM
Bump it hell, whack the hell out of the breaker bar with a big hammer,
that ill git-er-done
Old 08-12-2018, 06:26 PM
Bamafan Bamafan is offline
Inactive Member
My thinking also George, but didn't want to be jumped on for suggesting it.
[B]Larry[/B]
Old 08-12-2018, 09:41 PM
I've always had better luck with a very short wrench, and hitting it close to the end on the bolt. As a note... use the box end.
Seriously.... impact works best, but you can't take the bolt out with a wrench without holding the engine from turning.
Old 08-13-2018, 11:27 PM
rwairforce rwairforce is offline
I place a pipe wrench on the driveshaft which will keep the engine from turning.
Larger vise grips will work also if no pipe wrench can be found.
As has been suggested, an impact zips it right off.
I've done my 1440 and 1864 this way with success.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Tags
pto clutch
