Old 08-09-2018, 08:20 AM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Default Battery vs Magneto Ignition
How can you visibly tell if you have a Battery Ignition vs Magneto Ignition? The reason I ask is some Stens ignition switches are for magneto ignition and visibly look the same as ones supposedly for battery ignition. The terminology seems confusing because how could an engine start without a battery?
Old 08-09-2018, 08:31 AM
Look up the part number from the manufacturer, then cross it to Stens. This response is easier than explaining the different ignition systems, and why an electric starter has nothing to do with the ignition system.
That, or just state what you need a switch for, and we can tell you which switch you need.
Old 08-09-2018, 08:33 AM
What tractor are you working on? If it has a round coil then it's battery and if it has a spark plug wire coming from the blower housing then it's magneto. Kohler engines with a magneto should be marked magnum.
Old 08-09-2018, 08:50 AM
Terry C's Avatar
Terry C Terry C is offline
I’ll try, they both need a starter and battery, mag creates its own spark and doesn’t need the battery after the engine is started, it needs to be grounded to make it stop. Battery ignition needs the power from a battery to create the spark via the coil all the time.
So I hope that helps with understanding what the switch has to accomplish.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-09-2018, 08:54 AM
I replaced the ignition switch on my 682 (with a KT-17 Series I engine) with an OEM 925-3021 switch. I like to have spare parts on hand but could not find the Stens number.
Old 08-09-2018, 08:55 AM
That's a better question.
KT17 is battery ignition.
