Old 07-21-2018, 07:43 PM
Just rip the wiring off. It really doesn't matter how it's wired currently.
Yes, you need a different coil. That isn't the right one.
Old 07-21-2018, 11:07 PM
Picture of the cam follower, and Mike Lamar's wiring harness for the Original. Do as Jon suggested. Pull the wiring harness, and start fresh. Everything is clearly labeled. MUCH EASIER...
Old 07-22-2018, 07:40 AM
jaykhjr jaykhjr is offline
Thanks! Does Mike have a website or do I order through the forum?
Old 07-22-2018, 10:27 AM
smalljob's Avatar
smalljob smalljob is offline
Subscribed... Nice job
Old 07-22-2018, 02:54 PM
Thanks alot!
Old 07-22-2018, 03:02 PM
I took your advice. Ordered a coil and PM'd Mike about a harness. Ripped my wiring out but kept it intact just in case.
I tried my pullers on the front pulley with no luck... does the metal bar that goes into the slot on the shaft have to come out somehow first?
How about the rear pulley? I cant keep the motor from rotating enough to get the bolt loosened.
Boogered up something today... trying to pull the steering wheel I dug too hard into the threads on the top of the steering shaft.
Do you think i can rethread this or is it time to look for a new steering shaft?
Other than that it's coming along. Going to take the wheels off and go from there tomorrow or Tuesday depending on work.
Old 07-22-2018, 05:19 PM
Finally. Good deal.
No, you do not have to take the key out first. Clean up the shaft with some emry cloth, and a wire brush. You do have to loosen up or remove the set screws first... I remove them and spray Kroil in the holes. May need some heat on the center of the pulley. You need the puller from Jeff.
Why do you need to take it off? Paint?
IMPACT GUN. Go get one.
Oh, you can probably run a die down it and fix it. But you need to put a nut on while pulling the wheel until it comes loose. You are going to have to do something before you pull the wheel though because you swelled the end of the shaft now.
Old 07-22-2018, 06:10 PM
Finally. Good deal.
I tried heat on the center of the pulley, maybe not long enough though... I'll try again and do you happen to have a picture of the puller? I was using a matco 6 inch hub puller I borrowed from my dad.
I did get the wheel off. The shaft isnt so expanded that it wouldn't come off, but expanded enough to not thread the top nut on.
I need to take a picture of my starter... I'm not convinced it's the right model because of the way its attached to the mount. Looks like the guy used washers as spacers to make it for correctly. I'll take a pic tonight or tomorrow.
Thanks for the help again. I have the steering system completely out of the tractor... I noticed some odd things but I'll get pics before trying to discuss/ask.
Old 07-23-2018, 10:55 AM
Chad126's Avatar
Chad126 Chad126 is offline
You are making some great progress. Keep it up and keep us posted with pics! Looks good.
It's really nice to see someone ask for advice, apply it, and then give feedback. Too often it gets frustrating for a lot of guys to hand out advice and then never hear back from the OP.
Good work my friend. Again, keep us posted! I'm sure it's going to look great when she is done.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 07-23-2018, 01:16 PM
Thank you! J-Mech, Zippy1, and others have been really helpful. I'd have been lost without some of their advice.
I hope to get more work done on it this week!
