Old 07-08-2018, 08:27 AM
john hall's Avatar
Spoken like a SPOILED BRAT (be you 12 or 62) that has NEVER ran ANY machinery. Look, its old with a lot of EXPECTED wear. This machine was built to be supported by a dealer network and a parts dept. It was not designed to run till it broke and then discard, that is a relatively new concept in manufacturing based on newer manufacturing methods and also an evolving thirst for "newness" around the planet.
Do us all a favor, put that thing on CL as a running parts machine priced at $100.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-08-2018, 10:55 AM
cooperino's Avatar
Sum this up in one word "millenials" lol
Old 07-08-2018, 11:24 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Already did, but the problem, everything needs replaced, PO cobbled everything together: clutch plate, clutch arm, clutch arm bracket, all of them are worn way past the point of requiring repair. Seems like someone didn't take care of their tractor.
Basically, what I'm getting at is that it would cost more than I bought the tractor for to undo the damage the previous owner caused.
And all of the crap I said in the intial post just suddenly popped up after not running it for like 2 and a half weeks!
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 07-08-2018, 11:42 AM
I bet you have far less idea what your talking about than you think you do.
Guess what, they most always cost more to fix than we pay for them. You only paid like $150 bucks (or something like that) for the tractor. I mean, damn.... a good battery is $45. What the heck did you think you would have to spend on it? $20? If that's what you think, you better get out of Cubs altogether. If you want a cheap to fix, throw away mower there are plenty out there.
Old 07-08-2018, 02:06 PM
john hall's Avatar
To expand on J-Mech's statement. fixing up anything old is a gamble. Sometimes time and money are rarely an issue. Sometimes it takes tons of both. When you have done a few projects you can better understand that sometimes, some machines shouldn't be restored/refurbished. Believe me, I know as restoring antique farm equipment has been a hobby of mine for 35 years. I've pulled a couple old farm tractors in the shop only to pull them back out a couple weeks later. One was an IH ID9, the other an Oliver 70. Too much time and money for either one. I had an early 50's Ford F5 truck. I could crank it up and drive it around the farm. I was all ready to go restoring it. When I added up the cost of materials, I could buy a restored truck. I found another collector and sold it to him, just like those 2 tractors that were not worth restoring. If you are intent of fixing something up, get something that is in reasonably good shape and running. After you work on it you will better understand how to grade a project in the amount of work, money and timeframe required.
So you don't think I back away from a challenge, I'll leave you with these photos. I bought this tractor after it sat for 30 years under a tree. The only thing that would move was the front wheels, even the steering and gearshift were frozen. Dad and I finished it in about 10 months. I used my money only. I was the ripe old age of 18.
2072 w/60" Haban
Old 07-09-2018, 09:59 AM
Chad126's Avatar
Chad126 Chad126 is offline
Yep. Here is the parts list I kept for my 126, and I didn't even capture everything I bought.
Fuel lines $15
Decals $63
Sediment Bowl Gasket $6
Carb Kit $12
Plug, Filters, Condensor $30
Wiring Harness $87
Oils and Lube $37
Battery $38
Rear Tires $152
Front Tires $69
Rear Trans Gasket $12
Paint $165
Clutch Plate $32
Stainless Hardware $37
Total $754
Your heart has to be in this. Spending money on these should be like spending money on a new toy. I would be like a kid on Christmas morning when I had a package show up at the door.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 07-09-2018, 08:51 PM
sawdustdad's Avatar
Fuel lines $15
Decals $63
Carb Kit $12
Wiring Harness $87
Oils and Lube $37
Battery $38
Rear Tires $152
Front Tires $69
Paint $165
Clutch Plate $32
Total $754
I'd say you got away cheap. Most of my purchases also required
axle bearings and seals
wheel bearings
axle pin
clutch spring, TO bearing, teaser spring, clutch disk and often, a new drive shaft
PTO kit, bearing
starter belt
steering box parts, follower stud, bearings, seals
steering ball joints
rag joints (QLs)
iso mounts (QLs)
lights
light switch
PTO switch
ignition switch
fuses, fuse holder(s)
seat
brake pads (yikes!)
And, for most, an engine overhaul and paint job.
Sometimes wheels are needed.
A set of Tru Power ags and new tri ribs up front can run over $600.
I'm at $3000 to $4000 on most tractors.
Old 07-09-2018, 10:05 PM
Bob95065 Bob95065 is offline
I have a 1000 that I grew up on and a 1450 that I picked up as a basket case. The 1450 came with a #2 tiller, a box scraper, a set of wheel weights and a rough 44" deck. I got the whole package for $350. I hate to think of how much I put in it and it still needs tires bad. It's a worker and it tills our garden every year among other tasks. More importantly I like it and it makes me feel like I'm 16 again. There's some things you can't put a price tag on.
There's not a lot of Cub Cadets in California. I'm glad I have two. I tell people they are part of the Midwest I brought with me.
Old 07-11-2018, 07:22 PM
jbrewer's Avatar
jbrewer jbrewer is offline
You sir, are a Cub Owner!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 07-10-2018, 10:00 AM
Chad126's Avatar
wheel bearings
axle pin
PTO kit, bearing
starter belt
rag joints (QLs)
iso mounts (QLs)
lights
light switch
PTO switch
ignition switch
seat
brake pads (yikes!)
It appears I missed much more than I thought...
I didn't list brake pads, seat, fuses, wheel bearings, ball joints, and probably a half dozen more items. Goes to show that the list above must have been the one I was planning to show my wife. ha
