Old 10-21-2010, 09:23 AM
T-Mo's Avatar
T-Mo T-Mo is offline
GT2042
Engine
20hp kohler Command
Drive system:
Shaft drive 5 year limted warranty
Cruise control
HD cast iron housing w/BDU-10 Hydrostatic pump spin on oil filter
Steering:
Cast Iron Rack & Pinion
Front Axle Cast Iron with grease fittings 5 year limited warranty
3/4 spindels
Ball Joints 4 Automotive Style
Rear Axle Diameter 1 inch with dual steel drive hubs
Chassis:
Twin C channel frame fully welded
Fully enclosed engine compartment
Steel fender and Bumper
Electrical system:
Alternator 15amp regulated
Battery 12v 275 cold crank amps
Charging Flywheel Altenator
Monitor package Digital hour meter, oil service reminder, oil pressure indicator. Battery voltage monitor, Park & PTO start squence LEDs
Operation:
PTO Clutch Electronic fingertip engagement
Deck lift Manual 12 position spring assist
Brakes Disc Brakes
Seat Deluxe High back with arm rests
Front tires 16x6.5
Rear Tire 23x9.5
Forward speed 0-5.8
Reverse Speed 0-3.5
Fuel tank Capacity 4.5 gallons
Engine oil Capacity 2.0 qt
Transmission Capacity 5.7 qt
Wheel base 47 inches
Overall Length 72 inches
Mowing deck 42 inch twin blade
Cutting height 1.5 to 4 inches
Anti scalping 4 greasable wheels one nose roller
Deck drive Heavy Duty kevlar belt
Deck wash System
Warranty
4 years 150 hrs/5 year limited warranty
GTX2000
Engine
20hp kohler Command
Drive system:
Cruise control
Steering:
Power steering with tilt Cast Iron Rack & Pinion Housing
3/4 spindels
Chassis:
Electrical system:
Alternator 25 amp regulated
Operation:
Deck lift Manual 12 postion spring assist
Brakes Disc Brakes
Seat Deluxe High back with arm rests Gel suspension
Front tires 16x6.5
Rear Tire 23x9.5
Forward speed 0-5.8
Reverse Speed 0-3.5
Mowing deck 42 inch twin blade 50 & 54 inch triple blades
Deck wash System
Warranty
GTX2100
Engine
23hp kohler Command
Drive system:
Shaft drive 5y ear limted warranty
Cruis control
Steering:
3/4 spindels
Chassis:
Electrical system:
Monitor package Digital hour meter, oil service reminder, oil pressure indicator.Battery voltage monitor, Park & PTO start squence LEDs
Operation:
Deck lift Electric lift with height Position
Brakes Disc Brakes
Front tires 16x6.5
Rear Tire 23x9.5
Forward speed 0-8.0
Reverse Speed 0-4.0
Wheel base 49.5 inches
Overall Length 74 inches
Mowing deck 48 & 54 inch triple blades
Deck drive Heavy Duty Shaft driven
Deck wash System
Warranty
4 years 150 hrs/5y ear limited warranty
Noticed no hydraulic lift - probably because they don't offer the BDU-21, just the BDU-10 transmission.
Old 10-22-2010, 09:11 AM
gcbailey's Avatar
gcbailey gcbailey is offline
Is that paint scheme for the 50th anniversary models only? Like on the 3000 40th? Or is all hoods going to be 2 tone?
Gary
Old 10-23-2010, 09:50 AM
I totally agree, Bill.
Old 10-25-2010, 05:34 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
This is why my main mower is now an X700 Deere. I needed a newer mower (6 acres to mow) that my wife and kids could just jump on and run without too much trouble. I love the old rigs, but my wife does not.
After looking at how flimsy and cheap the new CC are, I had no choice but to buy the X700.
MTD, if you are listening, I really had a hard time with that choice, but my money went with Deere. Granted, it was twice the money, but it was 3 times the tractor. IT will also still be around to sit with my 782, 1450 and SO76 10 years from now.
Old 10-25-2010, 09:06 PM
steve59's Avatar
steve59 steve59 is offline
Looks like another poorly built "home owner" special from Lowes or Home Depot to me.
IH knew how to build garden tractors......I'll stick with my 122 and 1450!!
Old 10-25-2010, 10:04 PM
I agree with you, Steve! I'll also stick with my 100!
Old 10-27-2010, 11:12 PM
dcubfan dcubfan is offline
Talking 50th ann. cadet
I too was so hoping for the anniversary model to be somewhat retro. But to be honest it looks about like what I thought it would. Oh well, it just makes me appreciate all of our old ones that much more!!!!
Just mowed the grass the other day with a '67 125 and it looked pretty dang good!
Wonder how many people will be saying that about these new ones in 40 years? http://www.onlycubcadets.net/forum/i...ons/icon10.gif
Old 10-28-2010, 09:16 PM
plummcrazy1864's Avatar
plummcrazy1864 plummcrazy1864 is offline
Thumbs down
U think MTD would have done a better job than this. Make a well built good lookin tractor to celibate 50 years.... But no we get a spruce up version of the cheap crap their putting out now. Thanks but no thanks . Give it a BIG THUMBS DOWN
B.D.Robinson
1996 Cub Cadet 1864/w 54" Deck
