Old 05-31-2018, 02:19 AM
Originally Posted by fgaretired View Post
it didn't leak i just want to keep it from rusting again. If you thin it with astone and do a thin coat to keep it from rusting it wont peel. Most peope get it on to thick and it peels and they dont let it dry long enough by the time i put gas in it it wil be a year lol
I must have fixed a lot of tanks by people who don't know how to use it then. Well, not fixed them after that junk was in them. Threw them out and got another tank.....
I'll never put it in a fuel tank. I can weld, solder, braze or use JB weld, but I'm not using that stuff.
It won't rust if you keep gas in it...... water is what rusts a tank.
Old 05-31-2018, 07:48 AM
Well I am another one who dislikes that stuff.
I had to remove what was left of it in a mo'sikkil tank, what a job/mess that was.
it promoted more rust to form under it, making the proper repair more extensive.
Old 05-31-2018, 08:13 AM
We use Caswell gas tank coating at work and we've never had an issue. It's a two component coating so it's hardened and it dries hard as a rock. It's available in clear or black, I prefer the black because it's much easier to look in the tank and see that it's all coated.
Old 06-02-2018, 08:26 PM
fgaretired fgaretired is offline
O well different strokes for different folks. What works for some don't work for others.
Old 06-02-2018, 09:02 PM
sawdustdad's Avatar
I used Red Kote on my 72's gas tank about 5 years ago because it was riddled with pinholes. Too many to repair easily, though I suppose I might have tried to solder them. I figured if it fails, I'll get another tank. It's held up for 5 years OK. We'll see how long it lasts.
Old 06-02-2018, 10:15 PM
Billy-O's Avatar
Billy-O Billy-O is online now
Are you using alcohol free fuel? I reckon the booze in the fuel might not be too kind to the Red Kote as it isn't kind with many things in the fuel system. Just wondering.....
Plow blade
#2 Cart
QA36 snowthower
Old 06-03-2018, 08:01 AM
sawdustdad's Avatar
As a matter of fact, I do use non-ethanol fuel in all my cubs and lawn equipment. Fortunately, here in Virginia, it is still available.
I will note that use of Red Kote is kind of a solution of last resort. It is not a preferred fix for a leaking fuel tank, but may have value for some situations where alternatives are either not available or are not affordable.
