Old 05-27-2018, 07:11 PM
*Stens*
Sorry. I was autocorrected.
Old 05-27-2018, 07:44 PM
twoton twoton is offline
Looks like this would be the one;
https://www.kohler-engine-parts.opee...ducts_id=34555
Old 06-03-2018, 07:54 AM
Default Fuel tank repairs
When I went to look at this welder I noticed that there was some rust in the fuel tank. I also saw some signs of leaking from the bottom of the tank onto the starter. When I drained the tank there was plenty of crap that came out with the fuel, but lucky for me the screen was still intact. As the shutoff would not turn, I took it apart, cleaned and oiled and reassembled.
Old 06-03-2018, 07:56 AM
First round of cleaning involved multiple rounds of filling the tank about 1/4 full of boiling water with a heaping tablespoon of TSP and a hand full of 3/4" stones from the crusher followed by LOTS of shaking, drain and rinse,..repeat!
Old 06-03-2018, 07:58 AM
Next step;
https://www.amazon.com/dp/B00IKKQ2U4...v_ov_lig_dp_it
Old 06-03-2018, 08:40 AM
cooperino's Avatar
Originally Posted by twoton View Post
Next step...
I have never used that stuff before. I have always been curious how well it works. I assumed that and coating at some point would wear or flake eventually. Ford had a huge problem awhile back with Tanks they coated in factory.
If you have good success with this I would love to know. I have a very old tank off a hit/miss I would like to resurrect, been using a different tank on it.
Thanks
Old 06-03-2018, 08:56 AM
cooperino, First tank I did this way was on a motorcycle about 35 years ago. Worked well without problems for the appx.. 7 years I had it. Did 2 more tanks on equipment about 14 years ago. Still working well today.
Old 06-03-2018, 09:57 AM
If the tank is leaking, solder it, if it is not, no problem, nothing to fix.
Old 06-03-2018, 10:05 AM
Old 06-03-2018, 10:34 AM
....solder it....
ol'George, I always appreciate your advice and value your opinion. Thanks for commenting.
It is leaking. Once I got the tank all cleaned up I found several pin holes in the bottom. So,.. my concern is the rust inside the tank. Through the agitation process I feel fairly confident that I have removed all the loose scale but there is still surface rust on the bottom. The KREEM process involves removing the rust with phosphoric acid, rinsing with MEK followed by coating with the sealant.
I could solder the pin holes from the outside, but.. what would you suggest I do about the rust?
