Old 06-01-2018, 06:09 PM
samckitt samckitt is offline
Default 1872 eating fuel pumps?
Its on the 3rd one since i have had it in not quite 3 years. Maybe i am buying cheap pumps, which one should I buy? Or is there an electric one that would work better?
________________________
Scot
Old 06-01-2018, 07:28 PM
CubDieselFan's Avatar
I like these. Scroll down till you see the pump.
http://www.kirkengines.com
Old 06-02-2018, 08:09 AM
18XX's don't need a fuel pump unless you run the tank low on fuel or use the tractor on steep incline. My pump failed on an 1811 I had so I bypassed it and ran it for 2 or 3 years without any issues.
Old 06-07-2018, 09:31 AM
So i found out it is not the fuel pump, but it won't run unless I squirt fuel into the carb. Fuel hose is not clogged, so it's something in the carb. Suggestions where to start, other than "tear it apart & look for a clog"?
Thanks
Scot
Old 06-07-2018, 09:55 AM
mickb72 mickb72 is offline
Suggestion to start, rebuild kit. If you tear it apart and clean you might get by w/o the kit. Mike
Old 06-07-2018, 10:12 AM
Will a 17hp carb work on it? Neighbor is an old fart that b!tches about everything. Yesterday he was "jokingly" b!tching about the height of my grass, but I know deep down he wasnt joking. Can I run it until I get other fixed?
Scot
Old 06-07-2018, 10:22 AM
Yes a KT17 carb will work. Should really be a better carb, adjustable.
Old 06-07-2018, 10:24 AM
The carb for a kt17 is the same as a mag 18 so you can run it no issue. I recommend switching over to the kt17 carb permanently because it has an adjustable main jet were the mag 18 carb is fixed.
Old 06-07-2018, 11:05 AM
You may or may not have an issue with the choke cable, but you prolly will know once you look at the carbs side by side.
Old 06-08-2018, 10:03 AM
I didn't end up just switching the carbs, but rather took the M18 one apart. I found that the float valve plunger thingy was sticking & not opening up to let fuel in. Sprayed some brake cleaner through it & put it back together & ran fine.
Thanks
Scot
