I'm trying to fix my cub cadet 149 hydro. The trunion plate on the pump that's rectangle and holds the springs in it. Mine is wore out and needs repaired. Since its connected to a shaft that goes through the pump, is it possible to remove it for repair and if so how. Can I just remove the snap ring on the other side and slide it out or is there more to it?
I'm sending to to Jeff so he can weld a new plate on it so need to get it out somehow. Any help would be appreciated. |
Just repair it while it's still attached to the pump. You have to disassemble the pump to remove it and that's way more than you want to get into. When you're welding wrap a cold, wet rag around it to keep the heat from reaching the seal. Not to step on Jeff's toes but i think your going to need to find a local shop that you can take the whole rearend to.
That's what I was afraid of. Figured it couldn't of been that easy. Thanks for the info!
I have a repair plate he'll have to weld in place. |
If you are gonna take it someplace to be repaired, I suggest a thorough bath beforehand??
No one wants to weld on a filthy piece of equipment like that. Good luck! |
http://www.onlycubcadets.net/forum/s...hlight=Trunion
http://www.onlycubcadets.net/forum/s...04&postcount=6 A couple of links that might help you.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
Plus it makes welding more difficult and increases the chance of a defect in the weld.
You could add a piece of key stock to that by drilling and bolting it to the trunnion.
I have taken them apart and it does require some skill to remove it and it need to be clean as a monkeys sheen.
Looks like you need to replace the cork gasket. When you pull the hydro unit out to do that, take the unit somewhere and have it welded or weld on the new plate yourself. I've done a couple like that, as someone stated wrap a wet rag around the arm to protect the seal.
Ray 782, 982, 129 |
I was wondering if I would be able to weld the new plate right on top of the old one or if I would need to cut it off and weld it on.
