Old 10-21-2010, 07:30 PM
tinkerman73 tinkerman73 is offline
Default Thinking of horse trading for a 127 hydro
A local junk shop has a decent looking 127 hydro with I think 44 inch deck and snow blade. Runs and hydro lift works, both front and rear. He is asking $500. I am asuming this is a decent price? I am thinking of trading a good 1315 with 38 inch deck and some other things like a truck tool box and other stuff. Just looking for reasurance that this may be a decent deal as I know I have really been wanting a GT. How hard are parts to get for these if the hydro rear end goes or lift? Also how pricey do they get? Any words of caution before I strike this deal in stone? Thanks.
Old 10-22-2010, 01:35 AM
Unless a PO installed a hydraulic lift... The lift should be electric. 127's are very good machines, however it really all depends on how the tractor has been treated/maintained, and what repairs have been done (and if they were quality repairs).
I'm something of a pessimist with an optimistic outlook. I never buy a Cub Cadet without first assuming (I know you shouldn't do that) that it will need the pto, steering, clutch (for gear drives) trunnion repair and release valves repaired or replaced (for hydros) points, condenser, coil, voltage regulator, starter/generator, carburetor, and perhaps the engine all rebuilt/replaced/repaired. If you are willing to to do whatever it takes and/or spend the money to put this tractor back into good shape, then ANY IH built Cub Cadet will make you a FINE machine.
$500.00 sounds a little spendy to me, unless the tractor is in pretty darn good condition. However if you are trading off stuff that you don't really care too much about, then it may not be such a bad deal.
Drive it around, cut a little grass with it and see for yourself how it works... Keep in mind that if you were to "go through" this tractor from one end to the other, put it back to NEW condition you could spend as much as $2000.00 on it, BUT it will last 40 years. OR you can go spend $2000.00 on a brand new machine and then throw it away in 5 or 6 years. Not a difficult decision in my book...
But then again... What do I know???
Old 10-22-2010, 01:47 AM
$500 is a little steep in my opinion. Back before the economy crashed and burned, I had trouble getting $375 out of a 'fixed-up' 127 and deck. I can almost guarantee you that if you buy a tractor that the owner can't prove he's gone through and fixed all of the typical problems, you will have to go and fix all of those things. I never pay top dollar, or even average prices for these things because I know they will not be up to my standards without some work. I don't think I've ever bought a tractor that was claimed to 'need nothing' that I couldn't find one (or a dozen) things that needed fixing or replacing. Last one was my 1872...seller claimed it was 'ready to mow'... after six weeks, $300 in parts, and a new rearend, it was 'ready to mow'...
Old 10-22-2010, 08:37 AM
Thanks for the comments so far guys. The only one thing he is wanting is one of my other cubs. I kinda like to keep the LTS since they are both working good now. But we will see. All of the other stuff was free to me and I have it out for sale anyways. My long term desire is to restore it! The hydro/electric lift. I guess I learn something new. LOL. Yes, it is a push button thing. I have not had a good chance to go through the tractor yet and try everything out yet. I know I like the auto(hydro) rear end, the idea of the I guess electric lift, for deck/blade as well as the one in the rear along with the lights on it and possabilities of adding more equipment in the future! Heck, I would be willing to give up the old iron horse(troy bilt rototiller) to get a rototiller for that cub!(Though its engine would be a good back up engine maybe?) Downfall as you guys have pointed out, will cost a fortune to rebuild! My idea of rebuilding also, is to use the tractor and buy each part at a time and rebuild those, then once I have everything, or as I need them, put them on the tractor. Of course, doing that then eventually I would have a complete second tractor. LOL. Anyways. I may get a chance to spend more time there later and check it out more. I did note one thing, there was some old dry oil residue by the head. I am not sure if this is from it leaking then they parked it, so it still needs to be adressed, or if it had been taken care of is why its dry. I will assume the first. Otherwise, in appearance without it running, everything looked decent other then the seat.
Old 10-22-2010, 12:42 PM
RChristensen RChristensen is offline
Inactive Member
Any dry oil residue by the head tells you the head gasket is, or was bad at one time. If it was run for a long time with a bad head gasket the head could be damaged.
Old 10-22-2010, 12:52 PM
JayBrd's Avatar
JayBrd JayBrd is offline
A side from the general maint (or the possible lack there of), you are looking at trading a LT for a heckuva lot more solid GT.... I would say jump on it if he will trade for the 1315..
Jay N.
Eau Claire, WI
RED 82 Series...
Old 10-22-2010, 12:57 PM
jmroy's Avatar
jmroy jmroy is offline
Its a flat head, there shouldn't be any oil coming out from the head. Had to have been coming from somewhere else.
Old 10-22-2010, 01:07 PM
No...if it has a blown head gasket, it will be coming out from between the block and head.
Old 10-22-2010, 05:42 PM
Yes, theres the top thats what, about a inch or so thick? Along that seam between it and the block, more on the block side about a 1/4 in hieght about 2 inches long on the generator side is a thick dark residue, wich to me smells like old dry oil. The reason I am hesitating is because at this point, I have three hundred into the 1315 and it has been my main mower all summer long. I have had to put in new lift brackets and a new bigger motor out of a different tractor when the old one threw a rod. So my hesitation is now it is going well and has a strong tranny in it. What will come of this GT? I could get it, all seem good, then first time useing it all heck break loose. Then I only have one mower to mow with. Granted the mowing season is just about over and most customers are leaving for other parts of the world already. I will already have one LT with a plow on it for the winter and then this with a plow for the winter, so its not so important. However, my unemployment runs out next month and I still dont have a job yet, so I need to be hestitant. But, I am very eager to get a rougher tougher (hopefully) GT! Granted I know I love my two LT's (sorry you GT die hards LOL). But yes I have always wanted a nice older tractor after selling the old wheel horse 654 several moons ago and wanted something tougher like the old Bolens 1050 I used to have and I am of course, a big cub fan is why I own 4 of them right now. ( had to let the one in parts go) So thats why I be asking. LOL. I will have to see what kind of deal he really wants as I am hesitant to trade the LT and a bunch of other stuff to him for that as I know come spring, that LT will sell for honestly what that GT is really worth now! To me, it should be more of a even swap! So, stay tuned. One thing I think I will do this weekend after I get my legs back from the cortozone shot today will be take the 16 HP brigs off of the 1315 and put it on the 805 and put the 12HP briggs onto the 1315. Also swap out the rear ends since the 805 has slipped a little earlier this summer. That way I will know the 805 will be ready for some good white stuff! LOL.
Old 10-22-2010, 09:01 PM
Well, here is my report. Claims hat two months ago a new head gasket was put on. A new generator 2 years ago. Start it up and there is some smoke. The electric lift does work, but seems to go slow. Not that I have ever used one, but still, seemed rather slow to myself! We had priorly discussed the trade and was basically going to be even up kinda stuff. I again spent some time with that tractor. Then he came here. He liked my 1315 and how quick it was to start and how powerfull it was. We had discussed a 30 foot aluminum ladder, a 14 foot sluminum step ladder, a truck tool box, aluminum diaomond plate one with key, a ariens rototiller needing some work and a edger. Well, he decides he also wants the cub 75, a reese hitch, a bolens snow plow and a toro/wheelhorse snow plow plus a hundred. I said no thanks! I then asked what happened to our original idea we were working on and he said he needed some cash. I said alright then, how about the two ladders, tool box 1315 and a hundred. He said no, he needed more out of the GT. I told him good luck! So I guess I keep looking for a GT to play with and I still have a bunch of stuff to sell. I am sure if I was to put my stuff pon ebay and craigs list, I could get more and probably find a tractor in better shape for the same price or less. Yes I am dissappointed. But, not a fool either. Oh well. Sure wish he had stuck closely to his original idea of a deal!
