Old 05-04-2018, 11:33 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by Dirty Steve View Post
Red ones are cool! Good luck with the Conversion!!
Thanks Steve! I'm hoping that it will wind up being a fun project and not a pain in my rear!
Jay
Proud owner of the following:
Old 05-05-2018, 08:16 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Jay, you might want to see if you can find a 1864 that has the plastic trashed and a rusted out deck as a parts source. I have bought two of them to use on my projects. Might be the cheapest way to get the parts you need. I used the rear fenders and fuel tank and seat assembly from a 1864 on my 28 hp command efi conversion when I built it because it is easier to fill the tank. Another plus to this is you will have the dash parts to try to make the tilt steering work. Good luck with this project. I will try to post up some pictures of my 782 with the same mods for inspiration.
Tom
Old 05-05-2018, 08:47 AM
jaynjeep's Avatar
Tom
Tom,
Thank you for the advice.. I had thought about that, and Sam had mentioned that to me.. Problem is they just don't grow on trees around here.. I couldn't find an organ donor close by so have been collecting parts for several years to do this.. I know it's way cheaper in the long run to buy a donor but i'm too far in for that now.. I may go the rounded fender and tank direction/tilt column direction later..
Here is what I currently have to work with without spending any more money.. Two 782's (one IH and one CCC) a really nice low hour CH18 from an 1864 with the CV driveline, a driveshaft adapter and fan support from Jeff, A full power steering setup from a cyclops, a complete P/S axle and spindles from an 1862.. a really nice 50C deck from an 1811... I scored most of this stuff at a low cost because I wasn't in a hurry to find it..
Thank you for any advice or encouragement.. it's greatly appreciated.. I certainly can't argue with your advice after the beauties that you have turned out!
Jay
Old 05-05-2018, 03:01 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Ahh, nothing more pure than an authentic red ih 782. Good luck, looks like you have a good starting point
1- 1200 in pieces
1- 1864 in pieces
Old 05-06-2018, 12:33 AM
jaynjeep's Avatar
Yes Sir!... I still remember the day in 1980 when I saw my first new Red one in the IH showroom.. I was 9 years old.. never forgot it
Jay
Old 05-06-2018, 06:30 PM
Pat-CT's Avatar
Pat-CT Pat-CT is offline
The red ones are addicting!
Old 05-06-2018, 07:39 PM
jaynjeep's Avatar
Agreed fully!!... but so are the yellow and white ones!!
Jay
Old 05-06-2018, 08:06 PM
Jay I’m glad you’re on this one. One of my faves as well. Will be watching this one close.
I was oogling over it until I saw the Scrambler in the background. Knowing what you do for a business did you build it or buy it? Looks original but What’s the story on it?
Old 05-06-2018, 09:29 PM
jaynjeep's Avatar
Mike,
Thanks for the complements!! I'll need plenty of cheering me on to keep me motivated!
There is a long story behind that Scrambler.. I have known it since almost new.. it's all original.. I have bought and sold it twice in the past (unfortunately for me they were worth almost nothing during both those times). The guy that owns it now ( a distant cousin) had started a cosmetic resto on it. He sent it over here for some help with the restoration, (mostly minor mechanical). During the time it was over here he found himself in the middle of a divorce. Seeing what Scramblers are worth these days he kindly asked if it could "live" over here for a while.. lawyers are currently deciding on who it will belong to in the end! I'm staying out of it!
Jay
Old 05-06-2018, 10:27 PM
jaynjeep's Avatar
Default steering wheel puller
Worked on the 782 project for just a few minutes tonite.. I was dreading getting the steering wheel off.. but this handy puller makes it really easy.. about 3 minutes total
I bought this puller through a military jeep surplus dealer.. it's made for military vehicles with the small metal tube column and a bakelight type steering wheel.. anything from a Jeep to a 5 ton military truck.
I have found it to be excellent at pulling Cub Cadet wheels also! Doesn't even leave a mark on the wheel! This one is made by the Roco tool USA.. likely from the 50's or 60's.. they don't appear to be in business any longer.
Jay
