Old 02-06-2010, 11:28 AM
cubby123's Avatar
cubby123 cubby123 is offline
I spent 2 hours out in the brutal cold last night woorking on her. I adjusted the carb and then found out the gas tank is now dripping out gas all over the coil. Will this effect it? (I'm sure it will)
if you want a real tractor, you need a CUB CADET!!
Old 02-06-2010, 11:54 AM
Open the valve ALL the way, or try tightning up the packing nut around the valve stem.
Old 02-11-2010, 08:59 AM
Aroostook Aroostook is offline
Question
Running, yet?
Old 03-01-2010, 06:36 PM
Smile
Not running yet, huh? Does the 125 run? I know a place you can dump the 123, now that you have the "upgrade" 125. :biggrin2.gif:
I'll bet that if you get some time to re-read, maybe even print, the posts made in this thread that you can get 123 running. It's not rocket science, by a long shot. If the southwestern part of the State didn't have more snow than we do I'd suggest you throw 123 and a snowmobile on a trailer, get your butt up here, go sledding while I "play"with getting 123 running!
The Tractor Show in Eliot in July seems like a l-o-n-g ways away, but we're going to set our clocks ahead a week from Sunday. I think they just do that to give us up here something to look forward to!
Old 03-02-2010, 07:42 AM
cubby123's Avatar
Yah, the road to the tractor show is always a long one lol. I will have to hook up an extension cord in my house and hook a battery charger on that so i can charge her battery up. Maine doesnot want me to work on my cub. I have no power in the workshop cuz it has it's own line than the house. So i have no electricity. I havn't gotten that 125 yet but the guy is holding it for me. I will have it by the show though. I think I might be getting cubby going soon. I gotta feeling
Old 10-16-2010, 09:39 PM
cubby123's Avatar
UPDATE: Going to hone and put in new rings on the old engine and do the same for the new 10 hp that smokes. If anyone is looking for a 10 hp email me.
Old 10-19-2010, 09:34 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Originally Posted by cubby123 View Post
Well, I have worked a lil more on the cub daily and she just won't go. I am pretty sure that it's a carb issue and electrical because when I put gas in the carb she wont fire but will puff out white smoke. I am completely stumped if that's not it.
Dude, you've got an ignition problem.
Take the carb off.....have someone crank it over, and give it a light squirt of ether, direct in to the intake port.
If you're ignition is working at all, it'll fire.
Try yanking the motor, and bolting it down to a bench with lagbolts, through a 2x4 on each side to give the oil pan room.
That way, you can check everything much easier.
Just use jumper cables to a battery.
Fly Fishing is not a sport...It's a way of life.
Old 10-20-2010, 09:06 AM
cubby123's Avatar
Well I took the engine apart again after i replaced the rod I never got it honed or got new rings so I am going to get it honed for free from a guy I know I just gotta buy new rings and also I gotta buy new gaskets for all around. After I put it back together I will set it up on the bench and try it out
Old 10-20-2010, 01:56 PM
cubby123's Avatar
Also I found out the relief valve is rusted shut so there's another thing I gotta do but she should be ready to plow snow by winter.
