Bringing old post back to life.
What about 4 different cylinders? How would you do it? Run 2 - 2 spool valves, or a triple & single?
________________________ Scot |
Didnt read through all of it, but what I did read sounds like a 3 spool valve with a diverter solenoid to redirect to a different cylinder...?
![]() Quote:
It would do you good to read the whole thread. Maybe you wouldn't have any more questions..... |
This is my suggestion....
As long as you don't want to use more than one at once, that would work. But in that set up, the first valve takes priority.
![]() Quote:
Let's see, One hand on the Steering Wheel, and One hand on a valve, probably be OK.
The JD valve I used was a Dukes valve. I found the literature and have included the link here. Hope maybe it helps someone.
http://qccllc.com/sites/all/themes/m...Model-1627.pdf
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
![]() Quote:
Plus, if you go by the thought that you can only operate one valve at a time because you have to have one hand on the steering wheel, then you wouldn't be any good at running a loader. You have to tilt the bucket while lifting or you will dump the load. Should be able to rum at least 2 at a time. 3 if they're positioned right. |
Ever done That? A tripple spool is tough enough to squeeze into that cowel. Would think that would be next to impossible to do while retaining an authentic look
