Old 02-28-2018, 10:58 AM
Marko141's Avatar
Marko141 Marko141 is offline
Default 127 rear end oil change
So I am having some issues with my oil change. So far I did not intend to change my oil but when I removed bolts to add the gear box oil started to poor through the holes and when I tried putting the bolts back in there would only go back in about half way. So I have some questions:
Are all the bolts holding the cover on suppose to be the same length? I have 2 different sizes.
Also I can not get the oil filter off, I assume it's just the normal filter that screws on but I can not tell. I got the replacement 1410 filter from
NAPA and it looks like I should screw off.
The oil that was in it was cleaner than I thought, should I just leave the oil filter I have on it there?
if anyone knows the correct length of bolts that should be in the rear end without me looking through pages of manuals would be helpful.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 02-28-2018, 11:29 AM
Try to get the wrench to remove the filter closer to the pump, It will come off.
As for the bolts I do not want to look either, but they all should be the same length though...
Old 02-28-2018, 11:58 AM
Marko141's Avatar
I just end up squishing/denting the filter, could you elaborate on that?
Old 02-28-2018, 12:07 PM
The upper bolts should be 5/8" long
The three lower bolts should be 1/4 longer as in 7/8" to allow for the thickness of the hitch plate.
DO NOT install bolts that are TOO LONG, you will break out the casting inside.
Take a look at them, you already have the cover off.
From the looks of the bolts in your picture, some are WAAAY TOOO LONG and busted out one or more of the tapped cones inside the case and that's what's causing the leak.
Old 02-28-2018, 12:14 PM
Hitch bolts for the tiller plate are longer. Easy to figure it out, but like finsruskw said, don't use too long of ones.
Put in new oil.
Use a filter wrench, but it close to the base of the filter. It unscrews. Turn it the right way. Don't use the filter wrench to install the new one. Sometimes filters get stuck. It happens.
mattoney mattoney is offline
The last time I changed one of those filters, I used an adjustable cloth strap wrench and a ratchet and ended up collapsing the filter.
Next time, I will use a regular metal strap oil filter wrench with the built in handle. Like this. http://bidatools.com/wp-content/uplo...Cap-Wrench.jpg
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 02-28-2018, 12:24 PM
Marko141's Avatar
That is what I tried using but I couldn't get it on, there was enough room to squeeze it past, I didn't look what was in the way. I'll have to look, I'm off to work for the day.
Old 02-28-2018, 12:54 PM
Marko141's Avatar
Here's the dang thing. And yes ik something broke and i just discovered it, not sure how someone managed to break it.
Old 02-28-2018, 02:18 PM
I see an old filter, but I don't see anything broke....
Did you have a question? Looks like a stuck filter. Keep working at it. I've had to chisel them off before.
Old 02-28-2018, 02:52 PM
Looks like a broken rockshaft to me....
