That is Henry Ford Model T yellow. "Any color you want, as long as it is black"
![]() Good work! Now, lets see some more pictures as requested.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
As many others have already done, I utilized a K301 Flywheel, blower housing and bearing plate (have heard all arguments about cooling with 301 flywheel on 341...no worries) so no frame cutting/gussets needed.
I hand fabbed the air baffles out of 16g steel. Had to seal off the oil tube-dipstick mount/hole on right side and utilize a cam cover dipstick set up as the S/G would not allow for proper belt. (would have to remove dipstick tube to replace belt) Installed mechanical fuel pump. All fit as if made for the NF ![]() As for the color scheme...main goal was to get some tough paint on a tractor that will be used for work around here and prevent rust. As many may have seen from the pics, I have a CC71 in the background and may try a hand at "restoring". I forgot to add that I rebuilt and installed a creeper for this tractor. For those interested in some close-ups I will try to get them posted mid-week or so. But for now... |
Why a fuel pump on a gravity flow system?
Just another part to fail.....
Just though I would try something a little different. I kept the cover plate...so if it fails, it's a two bolt solution to fix.
I just enjoy working on this thing and trying different things is all. New to cubs so just a little experimenting.
Hey gscott! Great to see someone new interested in the hobby. I am with J-Mech on liking to see the tractors original, but I, like the others, can appreciate your quality work. You didn't torch up the frame or molest the tractor (
), guess that sounded bad, but that is how I see it. If you enjoy it, then that is all that matters!! Keep an open mind when you do something that others may not like. I would rather have people be honest with me than to patronize me with false accolades. Enjoy the hobby and welcome to the forum my friend. I am looking forward to seeing more of your creative work.Cub Cadet 123
Looks like a fine job. Those pictures represent a lot of work and effort--which I hope pays off as you use it.
Thanks for sharing your project with us!
Stanton 1980 IH 782, Kohler M18 IH #1 Cart, original IH 42" Blade, modified to 50" and hydraulic 2015 XT2, Kawasaki 23 HP |
Da fool pump is fer slap wheelies
----keeps da alky flowin'
