Old 02-06-2018, 08:43 PM
Disconnect the Governor, set the throttle at WFO, start it and walk away.
Old 02-06-2018, 10:24 PM
Dirty Steve's Avatar
Sam, I would bet Doc has thought about it!
Patience Doc, you gots to be close!
Old 02-06-2018, 10:34 PM
DieselDoctor's Avatar
I'll try Steve, but Sam's suggestion is right at the top of my list.
I was going to kit the Kohler carb to have it in stock anyway, so Ol George's recommendation of trying it shall be done.
Old 02-06-2018, 10:47 PM
Sorry Stan. I'm out of recommendations unless I hear it. As many parts as you have swapped around, I don't know what to think anymore. I've lost track at what was original, and what has been changed......
I think it sounds like an ignition issue. But that was my guess before the new coil too.
I don't know what to tell you on getting a good video. I just use my phone, but I have a Galaxy 5, so I just upload it to YouTube from the phone. Depending on what you have, that may or may not be a good option.
Old 02-07-2018, 09:33 AM
While looking at Tv last evening, and seeing a ducolax commercial, I thought, have you tried to run that thing without the muffler?
possibly something got into there and plugged it up.
A broken baffle, a drunk with a beer cap?
Hell you have gotten all the mechanical things squared away, it is just carburation or Ign. and I'm leaning toward carb.
Old 02-07-2018, 11:48 AM
mickb72 mickb72 is offline
BTDT with a 57 Ford with a 292, it ran at least 5 minutes. And another one just like it threw a rod and went 3 miles to get us home. Mike
Old 02-07-2018, 12:29 PM
I agree George, carb or ignition and I'm going to do both again. I had the muffler off and used a shop air gun to blow thru all the pipes. It seemed ok. I have a kit coming for the original carb and CubDieselFan is loaning me a mag.
Old 02-07-2018, 04:02 PM
But did you run it with the muffler disconnected?
Old 02-07-2018, 06:53 PM
No I haven't George. Next time I have it running I'll take it off. Hopefully I can get the muffler off of the elbows, otherwise I'll have to run it right out of the heads.
Old 02-07-2018, 07:40 PM
Muffler will not like to come off the manifolds. remove it with the manifolds @ the heads.
just so you or others know:
---- To remove the muffler without damage, from the manifolds, first remove muffler with manifolds,
then clamp one manifold in a vice, warm muffler spigot near cherry red with torch and gently tap around the muffler spigot with small hammer to break it loose and expand it slightly.
it will come off with tapping and twisting motion, preventing damage to muffler, be careful they are not robust.
you might have to heat/hammer a few times.
Repeat process for other manifold/spigot
By heating the muffler pipe, or spigot, it expands and the taping also expands the pipe slightly as well as breaks the rust bonding.
