Old 01-03-2018, 08:28 PM
jakeotter jakeotter is offline
Default Cub Cadet 129
Hi:
I have the chance to buy an old broke down Cub Cadet 129 on CL. Price is $125, but I’m sure I can get it for less. Says engine turns over but doesn’t start. I really just wanted to use it for some parts, etc. I’m curious though, how I could check the hydrostatic drive without it starting? Or if there’s a way to see if the hydrostatic transmission is working at all. I’ve heard that a lot of times these old broke down cubs get towed which destroys the tranny.
Also is that’s true how is the best way for me to move it without damaging the tranny?
https://images.craigslist.org/00E0E_...P_1200x900.jpg
Old 01-03-2018, 08:44 PM
Gompers Gompers is offline
Originally Posted by jakeotter View Post
Hi I have the chance to buy an old broke down cub cadet 129 on CL. Price is 125 but I’m sure I can get it for less. Says engine turns over but doesn’t start. I really just wanted to use it for some parts, etc. I’m curious tho how I could check the hydrostatic drive without it starting? Or if there’s a way to see if the hydrostatic transmission is working at all. I’ve heard that a lot of times these old broke down cubs get towed which destroys the tranny.
I, personally, wouldn't worry about the hydro being gone. That's very rarely the case with these things. If it is, they are generally available at a reasonable price.
You can move it short distances (to load it or whatever) without hurting it, but if the release valves are stuck you shouldn't tow it for a quarter mile or anything.
At that price, as long as there isn't a giant hole in the block, you can't go wrong.
Old 01-03-2018, 09:01 PM
Thanks! Yea I figured for that price it would be worth it even I all I did was get the 12hp engine running for a repower on another cub someday.
Old 01-03-2018, 09:12 PM
I have paid more for less before.
Old 01-03-2018, 09:33 PM
john hall's Avatar
What he said.
Heck get it running, it might be a good running machine.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-04-2018, 07:38 AM
jbrewer's Avatar
jbrewer jbrewer is offline
That's a fine price. If it turns over without it sounding like a cement mixer from inside, it'll start without huge probs.
Grab it before someone else does. The hydros are pretty indestructible :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-04-2018, 09:22 AM
Marko141's Avatar
Marko141 Marko141 is offline
I would grab it if I was closer
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 01-04-2018, 09:50 AM
Grab it like a rapper does before it is gone........
Up to 534 and counting...
Old 01-04-2018, 11:52 AM
Right now I only have a Cub 72 but wouldn’t mind a wide frame too. It’s not like I could really use many if any of the parts from the 129 on the 72.
Old 01-04-2018, 01:03 PM
jbrewer's Avatar
Well, heck if you've only got one, than this is a no brainer. Turn off the computer and go git 'er dun!
We're always here to help enable you!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Tags
cub cadet 129, hydrostatic, transmission
