Old 11-29-2017, 08:09 PM
Cab looks really tall...... maybe it's just the pic?
I have a Cozy Cab. It looks tall, and I think it is. They could have built it a bit shorter.
Your cab looks much taller than does a Cozy Cab.
Weld metal on the thing and put windows in it. Quit fartin around asking other people how to finish it. 90% of the guys on here can't even weld.
ALL cabs on CC look too tall IMO......
Old 11-29-2017, 08:36 PM
I don't disagree there. Even my Cozy Cab is a bit tall. If I built one, it would be shorter. Only advantage I see, is I can make a cab header and install heat and a radio and still have head room. Still want to do that......
Old 12-01-2017, 10:32 PM
If you adhere the windows with urethane, I don't see why they would need to be riveted. Urethane holds the big glass in auto's and even tractors (much more surface area of glass). May need to add a ledge or a lip for it to sit on at least on the bottom. You agree Randy?
True, you don't really need it. But, if you use a few rivets, you can dry fit and get all panels cut, then use the urethane with the rivets to locate and hold till cured. Just a personal preference.
You could even use all lexan and just paint the inside except where you want the windows.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 12-02-2017, 12:31 AM
johncub7172's Avatar
Lightbulb
Or, whether or not you choose to remove the cab during the hot summer months? A good custom cover shop could make sheets of weather grade canvas that snaps on. Then the rout of installing the other half of the snap to the frame,....
Old 12-02-2017, 09:00 AM
I'd add a few more gussets to counter the side to side sway being as how it is so tall. Especially if you go the soft cover route.
