Old 11-25-2017, 12:50 AM
mattoney mattoney is offline
Default 107 Lever Retaining Bracket
Hello all.
I'm trying to find a replacement "lever retaining bracket" for the manual relief lever to go on my 107. It's item 35 in this diagram. Holds the relief lever up so I don't have to while I'm moving it short distances.
Unfortunately, it is NLA so neither parts tree nor Cub Cadet Parts has listed the part number and I'm not having much luck searching by name.
Would anyone happen to know a part number I can search for? Thank you for your time!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 11-25-2017, 01:02 AM
It's just a little piece of angle iron with a hole drilled in it. Just make one. Otherwise, put up a wanted ad on this site. (Be sure to follow the rules for your post.) I'm sure someone has a parts machine they would pull the part and sell it to you. But you can make one for less than the shipping would be.....
Old 11-25-2017, 01:45 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I think I have a couple of those little brackets. I will check tomorrow and let you know.
Queen Of The Quietlines!
Old 11-25-2017, 10:25 PM
J-Mech, that's what I have right now for a . Just wanted to see what the proper thing was supposed to look like. Haven't been able to find one yet due to lack of info to start a search.
Delta Cub, thank you! Could you shoot me a PM if you find one? Thanks!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
Old 11-25-2017, 11:44 PM
You either didn't finish typing, or I don't know what you are saying (in red). I'm assuming you mean to say that is what it has on it now? If so, you made it? If not, then you may in fact have the correct piece. It is just a piece of angle iron, with the edges rounded and it's bolted on loosely. NBD. If you need one, sounds like Beth can help you out!
Old 11-26-2017, 12:31 AM
Dart1917 Dart1917 is offline
395 399 R1 Bracket, lever retaining
378 341 R1 Washer, spring
21 222 R1 Nut, 1/4-20 hex lock
Old 11-26-2017, 12:19 PM
ironman's Avatar
ironman ironman is offline
Might this help you....
Old 11-26-2017, 12:33 PM
DeltaCub's Avatar
PM Sent!
Old 11-26-2017, 12:53 PM
You know what? I have this exact part in a bag of spare parts. I didn't think that would be the right piece since it had two holes drilled in it, but I never could find where it was supposed to go.
Maybe I've had this piece all along. Thanks!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
Old 11-26-2017, 01:01 PM
I'm going to blame using my phone for that mistake! Phones and pencils always making me mess up my writing! I went back to edit my sentence and never finished.
Right now I've got an angle bracket that I recycled from some old shelving. It's about 1-1/2" x 1-1/2" by 1/2 in wide, doesn't hold the release lever up high enough, and it snags on things easily. Hence why I was curious what the original should look like.
If what Ironman says is right, I've already got the piece in spare parts. I thought it was a bracket to mount something else. If it's not, then DeltaCub has me situated! Thank you for your time everyone!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
