Old 11-12-2017, 07:19 PM
Maybe he fills his garage up with sand, and makes a ramp, then he drives them up there then removes the sand.
Up to 534 and counting...
Old 11-12-2017, 11:50 PM
familytime familytime is offline
2182 was not starting. Tracked it down to just simply needing new battery cables. The old one were corroded inside when I opened them up.
Old 11-13-2017, 06:43 AM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
I built ramps with a sliding rod lock system, and I use a winch to pull up/let down the vehicles. At 6'3" & 260 I used to muscle things around, but, but after creating pile after pile of old calender pages, big jobs require different strategy. One of my dads best lessons was, "if you work smart, you shouldn't have to work hard". I didn't stop for tractor going up pics. Please excuse the chaos, this was last year as we were moving in. In the 2nd pic you can see the brackets that the ramps drop over, then the rods are slid in to block them in place.
1450SGT
1641
528 SWE Snowblower,
Old 11-14-2017, 09:59 PM
PeterJ PeterJ is offline
Sunday was a beautiful day up here in MN for getting some splitting and stacking done.
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 11-15-2017, 10:24 PM
This is the same day as the previous pic. Our granddaughter came out for a visit and when she sees the cub, she makes a beeline to it. It's probably her last ride with "Poppy", as she's growing up too fast.
PeterJ
1863 48" deck, 3pt
IH trip plow
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 11-21-2017, 05:30 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I was replacing the steering joints on the 1641 today and found the gasket holder on the steering box out of position. The picture is not very good but you can see it hanging. If I decided to remove the box I assume I can separate it at the joint between the top and bottom section.
Cannon
Old 11-21-2017, 05:40 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Cannon
Yes. Be careful not to drop your balls. Its a CV joint. Good time to relube that, as there's no grease fitting on it.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-21-2017, 05:45 PM
Good point Terry, I wonder why it has two balls and a shaft, and the driveshaft has 4 balls?
Old 11-21-2017, 05:49 PM
Shrewcub's Avatar
Lewis, my Dad is Terry, I'm Travis.
I guess the low rpm doesn't require as many balls?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 11-21-2017, 05:54 PM
Are you sure, I get called names all the time, lois, lewy, loo loo, and such.
