Old 10-04-2010, 03:57 PM
bobscub2042 bobscub2042 is offline
Default Cub 2072
Hey team
Had a lot of wiring problems on my 2072, most resolved but now;
Occasioanlly, more than not, she wont turn off when the key is turned to the off postion
Any ideas ?
Thanks
Old 10-04-2010, 03:59 PM
Sounds like the key swtich to me.
Old 10-04-2010, 06:18 PM
Nope already did that
Old 10-04-2010, 08:26 PM
aagitch's Avatar
aagitch aagitch is offline
I had an off topic tractor that did that and I discovered the smell red wire that connected to the solenoid had come unhooked. Don't know if that had anything to do with it or if it was a coincidence.
Old 10-05-2010, 02:21 AM
ajgross ajgross is offline
Inactive Member
I don't have a diagram for that model but I would guess that there is a relay that kills the magneto that might be going bad. The way the magnums work is they ground out the magneto to kill the engine. Something isn't doing that.
AJ
Old 10-05-2010, 06:40 AM
Make sure there is zero ohms resistance between the Ignition Switch Case and and the negative Battery Terminal.
Old 10-05-2010, 10:53 AM
Roland thanks I;ll check tonight - what is there is resistance ?
Old 10-05-2010, 11:07 AM
Make sure the kill wire going to the mag is actually grounding when the switch is off. I suspect the kill wire is broken or has a bad connection or something.
Old 10-05-2010, 11:23 AM
YES.... In addition, make sure there is zero ohms resistance between the Crankcase of the M-20 and the battery negative terminal.
Old 10-05-2010, 02:52 PM
Thanks guys not sure where that wire is at becuse I dont see it on the wiring dia. but I search
