Old 10-01-2010, 07:15 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default ISO Mounts
Guys,
Does anyone have a real life picture, of how the iso mounts, mount? The new ones I got don't look like the factory ones, and it's gonna be a PITA getting my old metal inserts in the new bushings.
Thanks Jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 10-01-2010, 07:27 PM
Sounds like you got the wrong mounts. What you probably have are the ones that are actually for automobile sway bars. Some people will use 4 good original mounts on the bottom and 4 of the sway bar style on the top without the inserts in the top ones. The set I got that actually worked right were black and were designed to use the original inserts. If you want the insert to work on your style, you will have to run a drill bit thru the rubber to open them up enough to let the metal inserts work. The auto style rubber mounts are too soft in my opinion to use as a complete set for both upper and lower.
Old 10-01-2010, 07:36 PM
thenrie's Avatar
thenrie thenrie is offline
The OEM iso mounts come with a handy-dandy diagram. I'll see if I can get a picture and upload it tomorrow.
Tony
Stafford, VA
1650, 682...
Old 10-01-2010, 08:11 PM
steve59's Avatar
steve59 steve59 is offline
I put four on my 1450. Part number 759-3952 that I bought from Madson's with no problems.
Old 10-01-2010, 08:37 PM
jeffscub's Avatar
i bought mine through an "official" cub dealer. these are the urethane bushings. but i will still run a bit through them. and just to show everyone here in cub land how "blonde" i can be, i have a 1200 that i can look at to see how they go. LOL what a LONG work week, truly thank god for the weekend!!!!! time to go play. thanks guys for all your help!!!! jeff
Jeff
Old 10-01-2010, 09:21 PM
lowlyfzlucky's Avatar
lowlyfzlucky lowlyfzlucky is offline
I installed the urethane mounts with out the metal inserts. No vibration and seems to be fine.
Eric
1450 in progress..........
Old 10-02-2010, 06:50 AM
Will this help...... ISO Mounts
Old 10-02-2010, 06:54 PM
jeffscub's Avatar
yes sir, i appreciate that. i already got them in and got the engine running. only problem now is, it idles great, but i can't get it to throttle up with out dying. got to work on that prob. but not tonight. i am carrying my wife and daughter to the fair, they're the "sideshow" attraction. LOL thanks jeff
Jeff
