Old 09-04-2017, 12:46 AM
swacor swacor is offline
Default 1864 dual hydraulics
I was looking at putting a double valve on my 1864, I can get the valve and buy the Union or (fitting) to stack. I know there was a kit 759-3493a for this to be done but I'm sure thats not going to happen. If I can get the lines from a doner with the valve, do I just add lines to the doner lines to go to the front? Change has to be done to the upper steel line into the valve I'm adding on top, so what should be the next to do do this?
Old 09-05-2017, 10:05 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Don't need to change the steel lines, just persuade them.
Get your stud for 22.00 from cub cadet and go to a hydraulic shop for the o rings. The lines can be purchased on eBay. They won't be long enough so you'll have to make extensions... I think. I'd put in a tee to run a set to both the front and back anyway. Regular pioneer 1/4" female couplers are the way to go.
Good luck
1- 1200 in pieces
1- 1864 in pieces
Old 09-11-2017, 11:47 AM
Rex B Rex B is offline
Default Why?
I have seen reference to this upgrade several times, but I'm unclear on the purpose. Is this so you can operate the rear 3-point independently of the mower deck? Is there a how-to available?
Old 09-11-2017, 12:28 PM
It's to add a set of ports to the front of the tractor so you can hook up a cylinder to make a snow plow power angle.
Old 09-11-2017, 01:16 PM
Can the mower deck lift be separated from the rear 3-pt lift? It's a PITA to drop the mower deck, hook up the rear blade to groom the drive, then reverse the process to mow again. I am just about to do just that :/
Old 09-11-2017, 02:54 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Use the screw on the rear plate to hold the deck all the way up. Raise deck, turn screw clockwise as far as it will go, then your deck will stay all the way up, and you can use the 3 point without having to take the deck off.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-11-2017, 02:56 PM
It's possible but it will have to be custom made, that was never an option from Cub. We have a member here that did it to his so maybe he will chime in.
Old 09-11-2017, 08:18 PM
Would that be the "Downstop adjustment rod", L-shaped device sticking out the back?
Old 09-11-2017, 08:40 PM
Shrewcub's Avatar
That's it.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 09-11-2017, 11:55 PM
Rescue11's Avatar
There are ways! I did this one on the cheap I also increased lift travel, pretty much doubled the lifting capacity, and it's independent of the mower deck. In fact it will lift so much I bent the stock 3pt arm. The beauty is how you can an switch from operating the front/mid mounted attachment to the rear mounted attachment by moving the silverfish lever 1/4 of a turn. And visa versa. Oh it also locks the unused implement in its'"current position" via fluid lock.
http://www.onlycubcadets.net/forum/s...ad.php?t=48391
The next one is more complex, expensive, and has better results.
http://www.onlycubcadets.net/forum/s...=31710&page=12
Working on a new design, actually its designed I just need to build it now
1- 1200 in pieces
1- 1864 in pieces
