also checked fuse housing and fuse...both good
I replaced the wiring harness and all safety switches. Also replaced the solenoid and pto switch. I know, overkill....but it works now.
Now...second issue....PTO is slipping where the V shape is supposed to provide a 'stop' on the upper part of the clutch. The bracket from the frame looks good, but the top portion of the clutch has a slight 'wobble' and it lets it slip off the stop and the whole unit spins...ripping off the pigtail wire to the harness. I cannot tell if I need to replace the PTO or if there is supposed to be a stop under there that is missing or broken off. Unit is 2006. All input is appreciated thanks todd |
