I picked this 551 blower up cheap today. It has a little pain peeling and some surface rusting but that'll come right out.
IMG_5186.jpg When I got it home I wanted to hook it to my tractor and use that to get it off my trailer. What an adventure that was. My frankentractor has the 1641 frame, so it has a steel arm for the lift already there but it's not the same as the snowblower lift arm. I was taking the two Allen head bolts out to swap on the snowblower lift arm and one of them broke off and the other stripped the head out. now I can't get it off. What's the best way to resolve that? Hard to drill them where they are.
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Do a Micheal Jackson to it.
Lew..... sometimes you really top the cake.
What, turn it white? I don't get it...
Beat it!
Beat it!
A pic of the problem may help devise a solution. Sounds like your bolts are rusted tight or overtightened. We use a lot of Allen cap screws in industry and one of our tricks for worn heads is to drive a torx bit in to one that is worn. Yeah you lose the bit but whats a couple bucks invested in solving the problem. Doubt that will work in your case though since the head isn't worn from constant use.
This thing is what I can't get off to put the snowblower arm on.
IMG_5189.jpg IMG_5190.jpg That's the piece that needs to come off to install this one: Lift-Bracket-719-3097-Cadet-Parts.JPG I thought I could just hook the lift rod to this but it's not right. This thing leans toward the front and the snow blower arm is a little more back. I couldn't get the rod to reach adjusted all the way in. So I figure the only way to use this tractor is to get that off. I hooked it right up to my 1864 because it just has a plastic piece over that shaft that pops right off. I mounted the arm and away we went. I guess I could just use that but defeats the purpose of having a backup tractor.
This is the diagram, but I don't have the plastic indicator (part 19). I have some other metal arm there with an indicator built in. I've seen two 1641's with that same piece. My 1864 has the plastic indicator shown.
Capture.jpg So the piece in question is stuck on part #8, with the two allen bolts through it, both ruined beyond getting them out even after soaking them with PB Blaster. I don't think going Jacko on it is going to do anything. Only two solutions I see are to drill it with my right angle drill, or cutting wheel carefully into the side of it.
Did you try using a 2 jaw puller?
If the bolts are not stainless, weld a nut on the one broke off. Then might be able to turn out. Terrible place to get too. I had the other version with one bolt broke internally. Complete nightmare and waste of 1 plus hours of my life. Could not salvage the lift piece. Just don't ruin the end of shaft where the pieces go on. Good luck!
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
