Old 08-30-2017, 10:21 AM
There we go.
To be fair, that is a new motor..... not a Cub Cadet spec''d motor. And a 22hp, not 20.
Oh boy, picky picky...
This is in a 2185, they are suppose to have an "O" ring on it....
Up to 534 and counting...
Old 08-30-2017, 10:49 AM
YellowGT YellowGT is offline
Yep, it's a 1/4 turn cap, just like the ones pictured and it does have an O ring on it and I did turn it all the way and I do check it every time before mowing when I check the oil because it came off before. This is not my first rodeo. I've been mowing with a rider for over 40 years and have never seen anything like this happen before. My best guess is that after a year or so the O ring loses it's elasticity and becomes loose allowing the cap to turn enough to get blown off. Just wondered if anyone else has seen this happen. When I replaced it I got the exact part number listed in the manual after borrowing the one off my neighbor so I could finish mowing. I have since installed an oil cap detainment system (ty-rap) to keep the cap from turning.
Old 08-30-2017, 02:38 PM
There we go.
It is a Cub spec. Perhaps someone changed the valve cover. 20 & 22 would use the same valve covers.
Old 08-30-2017, 04:18 PM
Does it ever fall off/unscrew it's self, Lew?
Old 08-30-2017, 05:10 PM
jimbob200521's Avatar
I can verify that Cub did at one point or another spec an engine like that. The Command I have in my 2284 came from another Cub and has the same setup as in the pic you posted, Sam
-Ryan
Old 08-30-2017, 07:08 PM
No it does not unscrew, I just got done cutting the grass, but I still have to fiddle with the carb more. Another project.
