you said "patio deck"
Did somebody say patio?
I said, "I'd be better off replacing", but didn't say I was going too. Is that the way to go, if I was?
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
If the wood is in good condition removing, brightening and staining really is not that bad. If wood is bad then replace. many videos on refinishing on line to look at. I would use a solid stain, covers more and last longer.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
I agree that solid stain is the way to go especially on older wood but make sure you don't get something to dark, it will make the deck hot and burn your feet.
Composite is nice but depending on how your deck is made you may need to add more joists to keep the planks from sagging.
Just pulled all the old wood decking off mine and putting down Trex composite. Had to do some work on the framing because I'm going to picture frame it. Had to add some joists on the ends to accommodate.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
