Hello all
I'm about to rebuild the clutch on my 128 but have a question about the teaser spring. Do I have it right way in the mock up picture? I looked at the parts diagram and seen that it looks like I might have it backwards. The second pic is how bad the driveshaft and throw out were. |
Looks right to me.
You have it right. The parts diagram is wrong.
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus ![]() |
Hello all
I rebuilt the clutch on the 128 but now I'm lost on the adjustment. I think the clutch adjusting rod is to long it measures at 11 1/2" is that the right length ? I was reading the manual and I need .050 between the release lever and throw out bearing,As right now I have 7/16" with the adjusting nut all the way in. Here is some pictures the last 2 show how far the pedal is in the braking zone before the release lever comes in contact with the throw out bearing. |
Did you put the bearing in backwards? I can't tell.
Where is the teaser spring and the cup it rides in? (Called a spacer in the parts book.) I can't really tell in your pics.... Something for sure isn't right. |
Hello J
Here are 2 more pic's for you the teaser is inside the cup. With the pedal all the way down it starts to open. I'm using a stock I just painted it yellow. |
I am assuming you are using a cc oem throw out bearing.
Adding more washers behind the nut onto the adjusting rod will help.
