Old 04-27-2017, 10:02 AM
yettrbomb yettrbomb is offline
Default Tiller
Scored a tiller and gearbox on eBay for $102.50! Went and picked it up last night, all seems ok. Got to looking at the gearbox this morning and it seems the vertical shaft is bent. I'm gonna look into it more as time permits. And I need to make the stuff to adapt it to my 3 point. New pulleys and a mule drive for putting it on my 1812.
Old 05-08-2017, 09:50 AM
MI Cub MI Cub is offline
Nice, I just picked one up from a buddy. Trying to make heads or tails of what I need to make it work with my 1650.
Old 05-09-2017, 06:53 AM
I see what looks like a bend in your picture also'
It must have been dropped or something.
The main shaft is 1-1/4 diameter, would take a hell of a drop to bend that!
I just got mine back together last night after a rebuild. not fun OR cheap!!
Possibly one of the tubes is bent, but they are 1/4 inch wall tubes, tough stuff.
Does everything turn freely??
Old 05-09-2017, 07:43 AM
Fins, I'm not sure if it's bent or not. Everything turns freely. I think the shroud is bent. There's some questionable "repairs" done to that. If it spins, it goes in the dirt. Not pretty at all, but the intention was to make a worker! Did get into the gearbox, the vertical shaft is bent. I have it over at my buddies machine shop, he's gonna make me a new one.
Old 05-09-2017, 07:45 AM
MI, I'm currently in your shoes. I've seen pics, of guys that have done it on here. But can't seem to get my dimensions. Guess I just need to mount it up and start guessing!
Old 05-09-2017, 11:51 AM
It's pretty easy. I built my own adapter for an 1811 before I ever knew they made one.
Old 05-09-2017, 05:19 PM
It appears to be pretty straightforward. Wish I had a better way of cutting plate steel. I'm luckier than most, I have a torch but it's too hard to get a nice cut.
Practice. You can cut almost as good as a plasma cutter with an acetylene torch if you set it right and your steady.
Just have a welding shop burn one out for you. No waste.
Old 05-09-2017, 07:15 PM
I agree.
Question for you, since you made one. The piece that bolts to the tractor, did you use 1/4" or 3/8 plate? I was thinking using 3/8".
Old 05-09-2017, 08:57 PM
Good grief, no! I used 3/16". We're not working on a big machine here.....
Old 05-09-2017, 09:26 PM
Overkill is always better than being killed
