Old 09-14-2010, 03:03 PM
kwduffy's Avatar
kwduffy kwduffy is offline
Default 147 Project
Getting ready to dive into the 147, to disassemble it for paint and general refresh of the tractor. Will try to add pictures along the way of the progress.
Haven't done much to it yet except take off the seat and sand a bit of the fender deck to see if it is worth saving, since it is got quite a bit of rust on it and some pretty severe pitting.
First problem though, taking the fender deck off the tractor, there is the bolts under the seat and then the flat head screws that go through the foot rest pads. I got the ones under the seat out, but the ones in the foot pads are rusted on there good. Any suggestions for getting them off besides heating them. I've tried penetrating oil and brute force but all I am doing is messing up the head of the screw. I thought perhaps I could use an airhammer and snap the heads off and get replacements or even getting a cutting wheel for my air grinder, any other suggestions?
Old 09-14-2010, 04:24 PM
It may be too late for this if you wrecked the heads, but I have used an impact screwdriver on things like that with great results.
The best way IMO though is to heat the nut plate until it glows and then back it out...that works every time. A torch is a very handy thing...
Old 09-15-2010, 01:13 AM
kwduffy's Avatar
The heads are not wrecked yet, stopped before I ruined them. Didn't even think about an impact screwdriver, that would be a good idea though. I'll have to try that out and see how it goes. Thanks!
Old 09-15-2010, 06:58 AM
hillbilly hillbilly is offline
candle wax works miracles. heat the nut till red and melt candle wax on them the parafin will suck into the threads as they cool, this will also help them from galling on the way out. Works on the rustiest of threads.
Old 09-15-2010, 09:36 AM
hydrocub hydrocub is offline
Matt is right on ...that's how I did mine....heat and impact driver .
Works every time with no damage done .
