Old 04-16-2017, 05:21 PM
Bits-n-pieces Bits-n-pieces is offline
Default Lost spark???
I know this is not a Cub Cadet, but have found good help here before:
Working on a Kohler engine on a piece of machinery and do not have spark to motor.
12 V going into coil 12 V coming out of Coyle but no spark at plug?
What am I not seeing?
Could cool be bad?
Brian
Old 04-16-2017, 05:25 PM
Just checked ohms across the + and - terminal on coiland reads 3.5.
Going to assume coill is good
Old 04-16-2017, 05:33 PM
And what engine are you working on? Also not trying to be rude but I suggest that you use spell checker.
Old 04-16-2017, 06:33 PM
Could cool be bad?
Brian
Put your volt meter/test light on the points side of the coil and spin the engine. You should see intermittent voltage or a flashing test light.
If you have neither, you likely have a dirty set of points or point not breaking the circuit.
Old 04-16-2017, 06:35 PM
This should help you out.... Kohler K Series Coil
Old 04-16-2017, 07:29 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Sam do you think the spell-checker will generate enough voltage (lol)
Oz
Old 04-16-2017, 08:13 PM
Fellas,
Filed the points and that worked...
Oddly enough,
I had this engine running in December and put new points in it so I did not think they were the culprit...
THANKS SO MUCH!!!!!
Brian
