Old 04-08-2017, 05:14 PM
CubDieselFan's Avatar
Default Looking at a 1211
I have found a 1211 that is about 2 hours from me. Can anybody tell me anything about the engines? What series? I know that they are 12 hp single cylinder. Thanks in advance.
Old 04-08-2017, 05:17 PM
The engine is a magnum 12, same as the k series but with a magneto instead of points/coil. I love my 1211, it runs a 44" deck with ease.
Old 04-08-2017, 05:21 PM
That was what I was needing to know. It has the 44" as well. Thanks.
Old 04-08-2017, 06:54 PM
Engine mounting is the same setup as a QL.
Old 04-08-2017, 07:54 PM
Do they have solid mounts?
Old 04-08-2017, 08:06 PM
nope, they have the rubber crap. I had a 1210, ended up repowering it with a Vanguard 16HP. The Mag12 is a good engine I just hated the mounts and drive shaft issues. Probably should have bought a set of solid mounts from Jeff in pa.
Old 04-08-2017, 09:02 PM
The Mag 12 is still running great, Sam!
Old 04-09-2017, 02:46 AM
No.... it's similar, but different.
My 1050's mounts are solid. As far as I know they are original.... unless Ryan replaced them before I got it...
Old 04-09-2017, 07:14 AM
1210 & 1650 engine mount setup. Looks pretty much like a QL to me.
Old 04-09-2017, 09:26 AM
Sam, what drive shaft issues did you have with your 1210?
