Old 03-27-2017, 01:09 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default 482
Picked up a 482 Cub Cadet .What was the original motor size? It has a 16hp Briggs twin in it now not sure if it was changed or wrong decals should be a 582 Special. Need to get the serial # off it when it stops raining.
Old 03-27-2017, 01:14 PM
The 482 rolled out of the Factory with a 11HP B&S engine.
The 582 rolled out of the Factory with a 16HP B&S engine.
Yes, the model/serial tag will positively ID the tractor.
Old 03-27-2017, 10:29 PM
rocker582special's Avatar
rocker582special rocker582special is offline
It should be a 582 Special.
Rocky
Cub cadet 70,123(parts),125,582Special
Old 03-28-2017, 12:35 PM
Serial has 482 in it some one changed the motor.Thinking about putting a KT17 in it with a hydro rear end make it a 782.
Old 03-28-2017, 07:43 PM
You really don't want a kt-17, it has a poor oiling system,and parts are NLA mostly, I'd go with a magnum-18
Same engine design only upgraded in multiple ways, it was the last and best of the flathead opposed twin series.
Old 03-28-2017, 08:03 PM
Unless you put a hydraulic lift on it, it would be a 682.
If you do that, and want to sell the 90deg gearbox, let me know.
Old 03-28-2017, 10:10 PM
I have a friend that I sold a 1100 that wants the rear and drive line .I have an extra 90 box that I am not using.I have a kt17 serries 2 out of a Deere I was planning on ringing it and putting in it with hyds.Pm me about the box.
Old 03-28-2017, 11:23 PM
IIRR a KT out of a deere has a different size crank on the PTO end.
Better measure it first, cub is 1-1/8" seems like Deere is 1"
but I forget somethings.
Old 03-29-2017, 01:05 PM
Some of the clutches you can take the bushing out and make them fit that is least of my problems.
