Old 03-15-2017, 08:44 AM
najohn682 najohn682 is offline
Default 682 Hydro Unit PTO?
Is there a port on the IH CC Hydro Unit that allows one to tap into the Hydraulic pump and plumb in a Hyd. PTO?
Is that better done driving a pump with the front electric controlled PTO?
Old 03-15-2017, 09:01 AM
IIRR the 682 is not a "ported hydro" so no provision for external hydraulics.
A ported hydro could be swapped in from other like units, IE. 782, and quiet lines.
But you would only gain hyd lift and/or aux outlets.
The GPM's of those pumps is small, if you are thinking of a hyd pto, a divorced pump would be a better option.
I/we do not know your abilities or what you want to power with a hyd pto.
---hope this helps
Old 03-15-2017, 11:08 AM
That is correct. It did NOT have a ported pump.
---hope this helps
