![]() Quote:
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
You used this on the transmission cover? Is that something recommended to do? I'm concerned that the cover won't mate perfectly (why else wouldn't the previous owner have fixed this leak is my thinking).
Nias Nebraska |
![]() Quote:
Nias Nebraska |
![]() Quote:
I'll have to steer you away, as I dont have your tractor so,....I dont know if bolt holes are cracked or what. Clean up the cover or where ever its leaking from. Check for tightness on all the bolts? Axel seals?
That's okay. I've got enough information now to do damage and give this a try on my own. I can put internet in the garage and position the monitor just right and then everyone can look over my shoulder should it come to that.
I found a local dealer that will sell me the Hytran in bulk for $11 per gallon (and that's cheap enough for me; beats $7 per quart). Thanks!
Nias Nebraska |
Tonight I filled up the trans.axel with the 1gal. Hy-Tran and was not full. So I added some of this Lubri Matis high performance gear lubricant, sae 85w140 ep.,/ with limited slpi differential protection. 1-1/2qt. of this. I thought it was too much. Now waiting for leaks. I'll steer it around tommrow, I think I had enuff cure-time on the gasket job. The plasticcyclops 089.jpg street elbow I found was the ticket. So I'd have to say I will be buying a steel street elbow and simply hold the funnel and oil to it. Worked well, and quickely drank it up......way faster than my good'ol idea of the rainbow pump oiler! I did not here say how you guyes do it, but this worked for me.
Yesterday I finaly got some seat time. No leaks here! That type of gasket sealer worked great. I had always thought of it better than the blue rtv.No need to post picts.!
