Old 01-20-2017, 06:52 PM
Default Workin' on a project
The things they do to these 149's.
More to come.
Up to 530 and counting...
Old 01-20-2017, 06:57 PM
Dirty Steve's Avatar
Ouch.
Old 01-20-2017, 07:00 PM
budscub's Avatar
budscub budscub is offline
Default I Mean......
How the heck does one even do that?
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 01-20-2017, 09:23 PM
Fall off a trailer at highways speeds?
Old 01-20-2017, 09:38 PM
It had a tiller on it, maybe hit a rock.
Old 01-20-2017, 09:40 PM
Looks to me like it was involved in one of those I'm stuck moments where all the rocking back and forth was doing good while the tire was spinning until it caught on something buried in the ground and then snap.
Old 01-20-2017, 11:05 PM
I don't think you could do that again if you tried...
Old 01-20-2017, 11:10 PM
john hall's Avatar
Been around 2 that did that. One didn't hurt the rear, the other bent axle/rim/housing--we swaped out the entire rear end for the guy. Guess it all depends on how they "land".
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-21-2017, 05:33 PM
Maybe it was because the trunnion was in need of repair.
A little herky jerky I bet.
That is has been fixed.
Switched the ported part from the 149 to a good non ported 129 one with a nice trunnion.
Pics of the deal.
Old 01-21-2017, 06:58 PM
Good grief LP you got that one further down to the nub than uncle A does with the 169 right now. Seeing that you do, can you take a width measurement of the open area of that trunion. Mine is roached and before I weld it I was curious as to how wide it's "supposed" to be. Nice work and super clean that one is. I just switched over my hydro lift on the one 169 to the better one. Ported pumps are where it's at.
