Old 09-05-2010, 08:50 PM
mrcubcadet's Avatar
Default 105 Shaft
I have been hearing a little scratching/hitting in the fan area on my 105, so I got looking and two bolts holding the fan guard came out, so I replaced them. That stopped the scratching/hitting for awhile, but then yesterday it came back, and the bolts were tight. But I watched the drive shaft turn as I cranked it and it was bouncing around, so I checked the vibration disks and they were tight and looked fine. So then I checked the drive shaft, and it's bent. My question is, how could this have happened, and is there something else I need to replace besides the shaft?
Thanks
-105___ Tiller
Old 09-05-2010, 09:01 PM
nuzzget nuzzget is offline
I'm not entirely sure. It could've just warped over time or a bolt for it might of came a little loose. Thats all i got. When you get a new one just make sure its all aligned.
Old 09-05-2010, 09:17 PM
mrcubcadet's Avatar
Yes, I really don't know how it happened.
-105___ Tiller
Old 09-06-2010, 04:08 AM
Im just saying when i got my 127 it was bend a bit but how i noticed it it cause alot of vibration. The 127 also sat for a long time and such so i just assume it gets warpped over time.
Old 09-06-2010, 10:30 AM
mrcubcadet's Avatar
Did you replace the shaft, or just straighten it?
-105___ Tiller
Old 09-06-2010, 04:00 PM
Just replaced it. I don't know anything about straightening metal rods or anything.
Old 09-06-2010, 04:05 PM
mrcubcadet's Avatar
I wonder if my dealer would carry new shafts?
-105___ Tiller
Old 09-06-2010, 04:20 PM
Made my own for my 1250. 5/8 round stock from your local hardware store.
Old 09-14-2010, 06:57 PM
mrcubcadet's Avatar
Alright....I have found out that my shaft is not bent. The end that goes into the hydro's input shaft it worn. I have ordered a new flex disc (because I figured this probably wasn't good for it) but what should I do about this worn end?
Thanks
-105___ Tiller
Old 09-14-2010, 07:38 PM
hydrocub hydrocub is offline
weld it up and file down .....or make / buy a new one . I welded mine .
