Hi All -
I need to replace the driveshaft boots on my 2182 driveshaft. I read the service manual and it is saying that I need to remove the radiator in order to remove the driveshaft. I just wanted to see if anyone had any recommendations or tips before I tackled this job. I also need to replace the cork gasket between the hydrostatic pump and transmission. I am wondering if I should pull the pump and replace this gasket while I have the driveshaft out. Any recommendations/advice? Thanks! |
You do not need to remove the radiator, I use an allen wrench that fits on a 3/8" drive long extension. Then you can remove the 4 socket head bolts from under the dash tower. You may as well do the cork gasket at the same time. Personally I'd pull the whole rear and pump to do it. While you have the rear out pop the axle tubes, drill the oil drain holes in the case, replace the axle gaskets and be done with it. Oh yeah and put a set of Xtreme SGTrear end braces on it.
Links to threads I've done over the years. http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Good question Jibber. I need to do both jobs you stated on my 1782. Well, no boots but need to replace the rear adapter with a jeff in PA one. And yes, the manual does state stuff sometimes that might be unnecessary so it's always good to post stuff like this. Thank you and thank you Sam.
Such a low hour machine. Do those maintenance items and it will outlast you....
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Question, my plan is to remove the driveshaft first. So, are you saying that I should remove the 4 sockethead bolts near the front that connect the drive coupling to the engine, then remove the rear 4 bolts that connect the rear coupling to the hydrostatic pump, and the drive shaft should then slide out? It does look like a tight squeeze if I don't remove the radiator first so I just want to double check first. Also, do I need to remove the rear fenders to do this and the cork gasket replacement or will removing the tunnel cover suffice? Am just trying to figure out how the driveshaft will pull out. Thanks! |
