Old 12-14-2016, 06:23 PM
Default Plow lock.
I wasn't real happy with the way the plow was attaching to the 1050, it seemed like it could be easily ripped off so I made these brackets that go over the pin on the plow and bolt to an already existing hole. I've had plows come off in the past and this will hopefully eliminate that issue.
Old 12-14-2016, 06:52 PM
RedHawCadet RedHawCadet is offline
Looks like it should work well for you, nice work!
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 12-14-2016, 07:20 PM
If that breaks something more important is coming with it. Well done.
Old 12-14-2016, 07:21 PM
Kewl! My blade on my 147 has the QA as well, but the bracket that mounts to the tractor is long enough it has a hole in it that lines up with the frame so I bolt it just for added insurance.
Old 12-14-2016, 07:39 PM
Look good Tim. Ironically I was using mine on my 128 to level out a compost pile this weekend and it came off while trying to drag some stuff away from the fence in reverse. Guess I needed those. My QA lever spring is apparently broken or gone because the engine vibration makes the lever come down and unlock. Good idea you have there
Old 12-14-2016, 08:41 PM
After the pics were taken I was able to get a pin through the hole for a little extra insurance. This tractor is going out to my mother in law's which is pretty far from any tools, I'm just trying to make it as reliable as possible. When I finally get the plow on my 1211 I will be making another set, hopefully that will be real soon.
Old 12-15-2016, 08:25 AM
I got to plow snow last night and the plow stayed on, I guess they work.
Old 12-15-2016, 09:06 AM
Very nice Tim, good idea.
Old 12-15-2016, 12:43 PM
good idea.
Those are the only kind I have.
Old 12-15-2016, 12:49 PM
Tim, did you tap the upper hole for a bolt or just a bolt with a nut on the back side?
