Old 10-12-2016, 09:47 AM
TN_Explorer TN_Explorer is offline
Default Can I use these dual wheels on my 782?
I have a chance to pick up a set of dual wheels/tires at a good price. They are the right size but the wheels are 6 lug. They came of a Sears, but the seller believes they will fit. I think they have to be 5 lug to fit.
The long bolts connect the two rims together, but doesn't the inside wheel need to bolt to the tractor hub (5 lug)? That means I can't use these, correct? They are loaded and so will be difficult to transfer to my rims.
Old 10-12-2016, 09:58 AM
If your just going to use those wheels on the outside then they should work, 6 lugs doesn't matter on the outside wheels.
Old 10-12-2016, 10:08 AM
IF those are 12" wheels AND the rings fit where they should on YOUR existing wheels AND the holes (for the long bolts) match up with the holes in your old wheels, you could use the ones in the picture as the outside wheels on your Cub.
Those are some FUNKY looking wheels, from the picture they look like someone welded those centers into the wheel.
Take a Cub wheel with you to see if everything lines up.
Old 10-12-2016, 10:11 AM
That's a solid piece of advice right there.
Old 10-12-2016, 11:59 AM
Dane in PA Dane in PA is offline
If they came off of a Sears, they're off of an FF18, 20, or FF24. The hulks or "Supers" of the Sears world. They had 6-lug hubs, and usually ran 26-12-12 tires on 12-12 rims. So, the tires may be big unless you already have 26-12-12s on your 782.
Old 10-12-2016, 12:21 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default Duals
You need some DMI type duals that slip on and bolt in
Old 10-12-2016, 12:58 PM
Did you make those? Or buy them? Or is it just a pic off the net?
Old 10-12-2016, 01:01 PM
ambrola's Avatar
ambrola ambrola is offline
I am curious about that myself? They sure look good.
Old 10-12-2016, 06:41 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
That bolt pattern looks pretty big. You might be able to drill 5 holes inside of those for the Cub pattern. Take a tape measure too.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-12-2016, 07:44 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Found this chatter on another forum:
"Has anyone ever seen or have these? I just bought this set. They're made by DMI (Dietrich Manufactiring, Inc.) of Goodfield, IL (where I used to live before moving to Minnesota). You probably know the DMI name from their farm equipment. DMI was bought out by Case/IH quite a while back, and then became part of CNH Global. They still have the plant in Goodfield that makes some equipment but it's being shut down. These are just like the big farm ag clamp on duals. This 12 inch garden tractor size was a limited production from what I can find... there's not many out there. There's a Cub collector who made some reproduction sets a few years back, but these are originals. They're the only original set I've ever seen... just wondered if anyone else here has seen a set, and wanted to share the picture if you've never seen them. dmi.jpg"
posted in 2008
