Old 09-17-2016, 05:25 PM
Hope this helps. Let me know if you need anything else. If Jeff can return it to me pretty quick I don't mind sending it to him so he can copy it.
Old 09-18-2016, 10:04 AM
Vertigo1 Vertigo1 is offline
Thanks Oak.
Very nice pics. Not sure who "Jeff" is, but I contacted Mark Hellrung from the sponsor ontop each page. I will send him the pics / dimension's to see if he can make one.
Quick question, is there a "trick" to getting the impeller out of the housing after removing the bearings / axle? Or better left alone?
Thanks again,
Vertigo1
Old 09-26-2016, 08:16 AM
Question: The "bolt" on top of the 4 inch pulley, is it used to fasten the pulley to the extension, or the spindle, or both?
Vertigo1
Old 09-26-2016, 07:59 PM
I did replace the impeller on mine and I remember it was not real easy to get out but I did it.
That is a nut welded on top of the 4" pulley so you can tighten it to the spindle.
Old 10-02-2016, 03:51 PM
Thanks Oak, Mark is backed up right now. Maybe in a month, or so.
Old 02-18-2017, 03:14 PM
Hey Oak, Can you tell me where the spring attaches to blower on this 345 I have. It's been so long I can't remember. I see the hole on the arm of the flat drive pulley, but can't tell where the other end hooks to, from the manual.
Thanks,
Old 02-18-2017, 06:28 PM
Is this what you need?
Old 02-19-2017, 08:51 AM
That's perfect Oak.
Thank you...
Tags
2182, 293, 345, gt54
