Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 09-12-2016, 05:39 PM
AngleGangle AngleGangle is offline
Default Pre-production 1200 and more
While going through all the things that pile up in a shed, I've unearthed two tractors and related accessories. Neither has been started in over a year. I signed up here thinking about restoring them, but my greater goal is to be getting rid of projects.
The 1200 was bought used from the son of an IH Engineer and is supposedly a pre-production model that was given to him in recognition for his work. I know it has problem with the PTO.
The 1250 was running rough, not sure on other issues.
44A mower deck, snow blade and thrower.
I would especially like the 1200 to find a good home, but am at a loss for the monetary value for it. Everything is located about 40 miles West of Chicago.
More pictures here https://imgur.com/a/C9cNk
Old 09-12-2016, 07:55 PM
If you can document that the 1200 is pre production it will probably enhance the value to a collector. If not it's just a 1200.
Old 09-13-2016, 09:32 AM
Do you have an up close pic of the serial number tag on the 1200?
Old 09-13-2016, 01:24 PM
I recall seeing a photocopy of a "letter of appreciation" from IH to the engineer but it is not with the manual or service records. I guess unless that shows up, I'll treat it as a tagless 1200.
Thanks!
Old 09-13-2016, 01:26 PM
It does not have a tag. I took a partial of the engine serial. Are there any other frame pieces that might be of helpful?
Old 09-13-2016, 01:33 PM
Look on the rear of the differential on the left side there is a flat boss
It may be there.
Old 09-13-2016, 10:56 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Was the frame ever drilled for the rivets that held the tag on?
Jay
Proud owner of the following:
