Old 09-10-2016, 11:32 AM
Wackntack Wackntack is offline
Default Cub cadet 1450
Hello, i have a 1450 cub thats been acting up on me.
I can run it for about an hour n then it quits, it would run after awhile then do the same thing,
I put in a new coil, wire, and relocated the coil under dash, it fired righ up and i used it to backblade my driveway for about an hour or so and it was running great, then it quit, just like i turned off the key. So i waited a couple hours and tried to start it again and nothing. I pulled the plug, check for spark, nothing. So i opened up the points, cleaned them up, rolled over and i have spark at points but still nothing at the plug.even tried a different plug wire. I noticed that when i turn the key on, the coil gets really hot to the touch and its not even running, i thought the old coil was getting hot from running it so thats why i changed it. It pretty much did the same thing as the old coil but now i lost spark at the plug.
Any ideas? I checked n doublechecked all wires.
Old 09-10-2016, 12:22 PM
Put a 12V test light on the points side of your coil and spin the engine over. What does the test light do?
Old 09-10-2016, 12:55 PM
Flashes on n off
Old 09-10-2016, 01:02 PM
If the coil is getting that hot I'd suspect it's junk.
Old 09-10-2016, 02:25 PM
What kind, brand name, & part number did you buy...???
Old 09-10-2016, 02:33 PM
The brand is standard uc12, from auto parts store
I also replaced the condenser with new one.
This was the first time i used it since replacing both, only got a hour or so out of it.
Old 09-10-2016, 03:09 PM
mortten mortten is offline
That's an automotive coil without an internal resistor. You need a coil with an internal resistor of 3.8 to 4.2 ohms. Go to NAPA and get an IC64 coil or get the proper Kohler replacement.
Doug
QA-36A
42" blade
Old 09-10-2016, 03:27 PM
Do i still use the condenser with the IC64?
Old 09-10-2016, 03:50 PM
twoton twoton is offline
Yes. Condensor Primeline (part # 7-01338)
Old 09-10-2016, 04:39 PM
These are the correct Ignition Coils.
Standard OEM....
A Better Coil....
