Old 09-07-2016, 12:28 AM
It's a 169. Nothing "fake" about it.
Why is the tag on the rear? Well, I'm assuming that all you guys are getting your info from tractordata.com on the "proper" location of the tag.... that info is likely incorrect.
My question:
Is it a 13 fin 16hp? And where did the original motor go??
X-2
Old 09-07-2016, 12:32 AM
Ikswodolg Ikswodolg is offline
It is a 12 fin motor, which I guess makes sense. Sounds like the replacement 16hp were 12 fin. No idea where original motor ended up.
Old 09-07-2016, 12:43 AM
Been thinking about this thread and I was going to ask where it was written that the tag had to be in a certain location after whatever date or serial number? Can someone post some links to this information?
Normally serial numbers and tags don't mean anything to me, unless it's about a low production Cub.
That said; after all these years who knows what parts have been changed and from what tractors these parts came from. If the tag or serial number is on the trans-axle, the only thing you know for sure is what tractor the trans-axle originally came out of.
Old 09-07-2016, 07:56 AM
I have (2) 169's and both tags are on the frame. One is very early built in April 1974. I'm thinking it's a home built 169 and you got a nice tractor for the price.
Old 09-07-2016, 10:53 PM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
I would have to second this, my 169 serial number is very close to this one and has the tag on the frame.
Mike
'62-O, 2-100, 71, 2-122, 2-123, 72, 127, 147, 108, 128, 149, 169, 2-1450, 582, 3-682, 2-782, 1811
1940 Farmall M, 1955 Farmall 300, 1967 Scout 800, Many Scout IIs, 1968 1200c 4x4
Old 09-07-2016, 11:12 PM
Guys, it can't be fake. The serial number indictates production date. The tag on the rear clearly is original to the rear end.
I'd say that the date stating when they moved them to the frame is incorrect. Or, it was a factory oops. Either way, the tag is legit and original.
Old 09-07-2016, 11:31 PM
red56turbo's Avatar
169's came with the serial number plate on the frame only. They were never on the rear end. Find a 169 tag, put it on the rearend in place of another model's tag, instant 169. The tag's real. The originality of the tractor is not. The first 169 built has the serial number plate on the frame as well as all other 169's I've seen, along with the two I used to own, one early serial number, one very late.
Under edit: That's a later serial number as well since this series ended in the 529XXX range.
Josh
Diesel Cub Cadets...........
Old 09-08-2016, 11:48 AM
danfeste danfeste is offline
If you look inside the tower from behind the gas tank the 169's had "69" drawn in there with a paint marker from the factory. Unless it has been painted over, or removed.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Old 09-08-2016, 08:13 PM
Heres the picture inside the steering tower
Old 09-08-2016, 08:37 PM
I don't know? Let me go check mine. Does it have the holes in the frame for the tag. Could the frame not be original to the machine?
