Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 09-02-2016, 11:14 PM
V30crewcab V30crewcab is offline
Yeah I'm thinking of making a plug for my haban 60inch and mulching them this year. do they may mulching blades to fit that deck?
I just got done puting out lime today, hoping to boost the yard a little since its almost dead from being dry so long. hadn't mowed in 2 months.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 09-03-2016, 12:10 AM
I use a lawn sweeper and dump them in a pile for my kids to play in, when there all done I sweep them back up and dump them in the woods.
Old 09-03-2016, 01:35 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Just like me! I know those are the neighbors woods, I've been to your house! it's all good, they won't read this!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-03-2016, 08:56 AM
john hall's Avatar
I have two trees, and a handful of annoyances some refer to as fruit trees that pretty much feed the squirrels. I do back up to the woods on 2 sides so wind puts a lot of leaves in my yard. I rake or blow everything to where I can get to them with the 128 and have a grinding good time. Preferably do it when it is dry. Sometimes the deck pushes them ahead of the front axle. I always blow the mower off when I'm done, never know where all that debris went. Dad has a round fender Deere 110 with a plate that goes over the end of the deck, it does well grinding them up but sometimes takes a second pass. I find it is best to not let them get too deep to begin with.
Now I do have to rake up hickory nuts, good grief them things are rough on a deck! Dad also has to deal with the cones dropped by a magnolia. If you don't know what they are, they are about the size of a hand grenade. Unlike a pine cone that is very brittle, these are fairly heavy and tough, mower decks won't even begin to grind them up. I did round them up one year using a snow thrower on a 129, talk about ducking for cover! I'm certain there's a Jeff Foxworthy redneck joke in there!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-03-2016, 04:11 PM
When I lived in CT I had nothing but trees around my place. Neighbor spent countless hours with his bagger cleaning up every leaf. His lawn was a work of art until the wind blew my leaves into his yard. I don't clean up leaves, God put them where he wanted them.
Old 09-03-2016, 04:26 PM
twoton twoton is offline
... I don't clean up leaves...
I don't clean up leaves either,.. unless it's for money.
Old 09-03-2016, 08:38 PM
Actually those woods belong to my landlord so it's all good.
Old 09-03-2016, 09:58 PM
Dirty Steve's Avatar
Growing up we had HUGE trees at my parents. We raked them into piles in the gravel drive way and burned them. Traffic would get slow and nervous. If we we in a hurry we would burn them sum beaches right in the lawn.
Old 09-06-2016, 09:48 PM
j4c11's Avatar
j4c11 j4c11 is offline
Always mulch your leaves into the grass. You can mulch up to 300 lbs of leaves per thousand square feet of lawn with no ill effects to the grass. It is good organic matter that improves your soil - leaves are rich in carbon and other nutrients. Applying a little bit of nitrogen like urea speeds things up, the bacteria that munches on leaves uses nitrogen in the process.
Old 09-12-2016, 08:29 AM
PSully PSully is offline
I've been raking them onto a big tarp, then dragging it into the woods to dump the leaves. I hadn't really thought about mulching leaves into the soil because I thought the leaves would be too acidic. I bought a 1042 earlier this year that has a deck with the plug, and mulching blades, so maybe I'll give it shot. Either that, or fill the yard up with Cubs so I don't need to worry about the damn grass!
