Old 08-04-2016, 11:59 AM
The 782 is looking good!
Old 08-08-2016, 08:53 AM
SGragg SGragg is offline
Inactive Member
Had a productive weekend.
Saturday, got the starter cleaned, bench tested and reinstalled. Runs good. Placed the M18 back into the frame to test it. Needed one item before I could test the engine, so moved on to the hub caps. Pictures below show the before and after. Used a piece of aluminum foil folded up and a can of Coke. Worked like I wouldn't believe! They don't look new, but I was impressed how they cleaned up.
Sunday afternoon, got the temp gas tank on, plugs in and magneto kill wire ready. Here's what an auction-bought, non-running Kohler M18 sounds like:
http://vid436.photobucket.com/albums...psxfo5nzju.mp4
Was good to know that I may not need to buy a replacement engine (yet) and can proceed to other things. Like pulling the tranny cover. The contents was surprisingly good. Gears appeared good and the lube wasn't a foamy milkshake. Tip for all who have never pulled a tranny cover: Keep the two top bolts in finger tight and then pull the bottom outward just enough to create the opening. Loosen the two top bolts as required to open the bottom more and more until it is drained. Otherwise, you'll end up with a huge mess. Also make sure your tub or container is 2 gallon minimum. I had to retighten the bolts, dump the tub to get all the tranny drained.
I know the wiring is suspect, so will be rewiring the tractor. Now that I feel pretty good about the mechanics of it all, I can move on with some speed (hopefully) to totally disassemble, clean, paint and reassemble.
More to come...
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 08-08-2016, 09:07 AM
The hubcaps came out great, nice work.
Old 08-08-2016, 11:54 AM
Great job on the 782!
Old 08-08-2016, 12:17 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Nice Work!!
I had heard about the alum foil and coke trick before! Glad to know that it works!!
Jay
Proud owner of the following:
Old 08-08-2016, 10:00 PM
mortten mortten is offline
Originally Posted by jaynjeep View Post
Nice Work!!
And people drink that stuff.
Old 08-08-2016, 10:50 PM
782 is coming along nicely.
Good job on saving the hubcaps, turned out great.
Old 08-10-2016, 07:58 AM
Inactive Member
Didn't spend much time last evening, but got the tractor de-veined and the steering wheel removed.
Busted a fuse holder, but no other damage done. Current wiring configuration may have worked, but PO had a separate grounding switch for the mag, which I'll replace with a harness based on Mr. Bedell's wiring diagram with relay. Most connections were rusty. The wires inside the harness looked old, even though the wiring harness itself appeared fairly new. Looks like a project the PO was in the midst of when he passed. Hard to say w/o any history.
As you can see, the plastic dash will need some repair.
Does anyone know if the plastic knob on the end of the hydro lever pulls off or is threaded? Need to remove it so I can remove the dash.
EDIT: Just looked on Parts Tree. Appears the knob is threaded onto the lever.
Stanton
Old 08-10-2016, 08:03 AM
Hubcaps look great, looking good, keep it up!
Old 08-10-2016, 08:49 AM
ccguy's Avatar
ccguy ccguy is offline
Beautiful work. Bravo.
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
