Old 07-16-2016, 05:22 PM
Gregory Gregory is offline
In re-conditioning the axle, I pulled the pressed in zerk fitting and replaced with a new one. This was drilled with a 1/4 in bit and tapped. The new zerk was screwed in and seated.
Old 07-16-2016, 05:36 PM
I installed the steering column and the clutch. The clutch is not going to be taken apart for it had been done previously a few years back and worked perfectly. Didn't see a reason for doing it again. The mounting bolts I've replaced with stainless ones. I did this for a reason but the biggest is for a grounding spot. The original ground was on the instrument / steering column bottom bolt. Since I don't plan to use original ground spot, I need a bolt isn't going to rust up on me creating electrical problems.
Old 07-16-2016, 06:15 PM
Great job Gregory. Can you provide us with the member who has the tapered spindle pin deal? (Jeff? Mark?) btw Jeff makes the steer axle pivot pin and bushings for our cubs too. Very cool redesign to tighten it up as a combination of three or different areas gives a very loose steering.
Old 07-16-2016, 06:24 PM
Very nice work, keep it up!
Old 07-16-2016, 08:52 PM
Yes Alvy, the gentlemen's name is Pete at http://www.spaco.org/loose.htm
It's been a few years since I ordered this, but I was impressed with how it worked. Once I finish with the steering assembly we'll see how tight everything becomes.
Upon drilling out the roll pin hole in the spindle which was shaped like an olive, as listed in Pete's documentation.
Old 07-22-2016, 06:52 AM
Need the collective wisdom from the group on trans-fluid. I drained the fluid and cleaned out the rear end of any trash and sludge. When filling with oil, do I used hi-tran or 80/90 gear oil ?.
I've painted the remaining engine parts and the engine will go in this weekend along with other frame parts. Trying to get it going and asking for advice.
Greg
Old 07-22-2016, 08:19 AM
I've always ran 80-90 in my geardrives.
Old 07-22-2016, 08:33 AM
Merk Merk is offline
Greg
Some will say 80/90 gear oil.....Repair manual says Hy-Tran or 30 weight motor oil. I use Hy-Tran from Case-IH dealer.
Project Uncle Dick
Cub Cadet 70
Old 07-22-2016, 09:02 AM
I don't remember ever seeing 80/90 gear oil in any Cub Cadet literature.
SAE 30 or Hy-tran.
Old 07-22-2016, 10:04 AM
mhasewinkle's Avatar
mhasewinkle mhasewinkle is offline
Hy-Tran is the way to go.
Mike
70, 71, 72, 73, 100, 102, 125, 124, 128, 147
1200, 560 Farmall, 340 IH, #2 cart
