Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 07-09-2016, 02:18 PM
Dirty Steve's Avatar
Default 149
Saw this the other day. Guy threw a number of $350. I declined. Just put over $400 in tires on the 2182. But Hydro lift with a sleeve hitch? The steering seems to have issues. Hood is buggered and would not open. Said it ran but I did not start it. Has a 44 inch rounded deck. Would not be original, right? It certainly has its issues. What do you think it is really worth if it runs with no smoke, front PTO works, deck spindles do not warble, moves under its own power, and deck goes up and down???
So why get it? Thinking about a sleeve hitch plow and a rototiller. Of course, could put stuff like that on the two supers I have already.
Old 07-10-2016, 09:09 AM
Around here that would be a bargain.
Good looking tractor, already has Ag tires.
Providing it starts and runs, moves on its own ect..
Just my
Old 07-10-2016, 09:23 AM
john hall's Avatar
The way you described it, it should mow grass, aside from the steering--not to say it doesn't need TLC. In that condition $350 would be a decent price (depending on steering issue) if it had turf tires, no sleeve hitch and no hydraulics. If the guy tossed out $350, he'd probably take 50-75 less. If you can crank it up and drive it around, it should be worth that.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-10-2016, 10:37 AM
Looks decent, runs, drives, everything looks like it's there even the little side panels. And hydraulic lift for the tiller is almost a must. You'd be doing just fine getting it at $300 to $350
Old 07-10-2016, 11:25 AM
You do know that the hood has a pair of hood latches at the rear? They look like a bent wire hook.
If that runs I'd give the guy his asking price. Figure on rebuilding the steering box. Maybe drive shaft and PTO. They are great tiller tractors.
Old 07-10-2016, 08:07 PM
I agree, that's a pretty good deal.
