Old 07-03-2016, 10:02 PM
ccguy's Avatar
ccguy ccguy is offline
Looks like the owner took very good care of the machine. Very, very nice. Congratulations!
INTERNATIONAL HARVESTER
- A Great Farm Heritage Comes Home.
1811/682/782/1440/IH #4/IH QA 42"
Old 07-05-2016, 03:06 AM
GERKS 149 GERKS 149 is offline
Since I will have to put new motor mounts in, should I get a rail setup welded together? I don't have a welder, so I'll have to find one! Anyone have one? Any good mounts on the aftermarket side or should I go with factory Cub mounts?
Old 07-05-2016, 08:28 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Have a qualified welder connect the rails. There is an excellent procedure here outlining this necessary modification.
I have had very good results with the OEM Cub Cadet engine mounts. Keep in mind it is an old Quietline and it will continue vibrate and rattle to some degree.
Good Luck!
Queen Of The Quietlines!
Old 07-05-2016, 09:08 PM
I make solid mounts and could do the cradle mod too.
Jeff
Old 07-06-2016, 12:54 AM
Jeff, how much vibration is there with the solid mounts? The cost compared to Cub mounts?
Old 07-06-2016, 10:07 AM
Terry C's Avatar
Terry C Terry C is offline
Sorry I'm late to the party. That is one nice 1450!!! Congrats
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-06-2016, 11:25 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
I didn't notice much difference with solid mounts on mine. Although I had lots of rattles before. I have sorted most of those out. But, I used to own an old Wheel Horse, and my 1200 certainly doesn't vibrate any more, and I don't think it's any worse than any other old tractor with a big single cylinder engine.
They didn't use iso-mounts before the QL, and those machines seemed to do alright.
As for cost, if you plan on getting "official" Cub Cadet mounts, solid is cheaper. Even used ones run a pretty penny.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
