Old 07-04-2016, 07:58 AM
nkeel8106's Avatar
nkeel8106 nkeel8106 is offline
Default 1863 Starting Trouble
I believe that I have seen a post before on here about starting issues with the cyclops cubs but I am unable to find it with a search...
For some time now when turning the key to start, I only get a click. It may happen once, twice or several times before it actually turns over to start. My battery is good, no problems there. Where do I go from there? Switch or something else? Figured since my grass is all brown and I have some down time it would be good to get whatever is wrong repaired, gets old turning the key several times before it will turn over. Thanks.
Nathan
Gardners, PA
Cub Cadet Yanmar SC2400
Old 07-04-2016, 08:37 AM
The first place I would start is the Battery Cables. Make sure, that each cable is clean, bright, and tight on each end.
Old 07-04-2016, 08:58 AM
And I'll add to that, connections on the back of the ignition switch.
An intermittent electrical problem is hard to trace/find because you can't fix what is not broken @ the time.
A starter solenoid, over years can and does corrode/ark internally as is the nature of it's operation and can cause that problem also.
I don't think there is an easy way to correct the problem when it is not occurring, short of replacing everything in the starting circuit.
Even worn brushes in a starter can cause that condition.
As a long shot, when it acts up and just "clicks" hold the key in the start position for a while. then feel for a warm or hot connection in the starting circuit.
it don't always work, but is about the only thing you can do short of replacing a lot of good components.
It is nice if you have a donor/ similar tractor that you can substitute components with out having to buy them.
Old 07-04-2016, 09:29 AM
Check the wire connections as described above. If that doesn't fix it, I recommend you take this route to fix your problem.
http://www.onlycubcadets.net/forum/s...ad.php?t=44607
Old 07-04-2016, 09:33 AM
nkeel8106's Avatar
That was the link I was looking for. My battery and terminals are in good shape. Thanks!
Nathan
Gardners, PA
Old 07-04-2016, 10:23 PM
PeterJ PeterJ is offline
This is a good write up by jimbob200521:
http://www.onlycubcadets.net/forum/s...ad.php?t=38545
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 07-14-2016, 08:39 AM
nkeel8106's Avatar
I ordered my kit from Amazon and installed in about 10 min last night. Worked perfectly! Starts great each time. Thanks jimbob200521!
Nathan
Gardners, PA
